Question about Sony KV-28FX60 28" TV
5 BLINKS MY TV IS KV-36FS76U AND I HAVE EXACTLY SAME PROBLEM,SWICTHS ITSSELF OFF TO STANBY AND BLINKS 5 TIMES AND AGAIN AND..TOO BIG TO TAKE TO REPAIR AND CANT FIND SOMEONE TO COME ROUND,,YET! ANYONE KNOWS WHAT THE PROBLEM WOULD BE? PLEASE.
  • Anonymous Nov 08, 2007
    Hi Bill,
    Thanks for your help,I have unpluged ''C'' board and powered it,got good audio but with in 15 second switches itself off again.Is that means IC 702 is the problem or its somethinkelse.Let me know please,regards.
    Railman
jedimasteryo
    New Friend:
  • 3 Answers
I had the same problem, my telly was showing error code 5, led blinking 5 times and then the telly enters into standby mode. There is a great site with pictures of this telly and I found the answer here:
Error Code 5 - Tube Gone
Hope it helps.
Posted on Aug 26, 2011
William Rayburn
  • 934 Answers
My first guess is IC 702 in the crt drive circuit. You could open the back and unplug the "C" board from the back of the crt and then power it on. If the set comes up and you have good audio that will isolate the problem.
If IC 702 is the problem you'll have a couple of other things to check, R533 .47ohm 1/4 watt fusible resistor and C541 22uf 100v both on the "A" board because they tend to stress when IC 702 begins to leak. Replacing IC 702 and not the resistor and cap could cause 702 to fail again.
If IC 702 is not the problem then it could be the flyback.
Hope this helps!
Bill
Posted on Nov 05, 2007
SONY TV. STANBY TIMER FLASHING
Hi Frank,
Please let me know if it has a pattern of blinks (separated by a pause) or it will flash an exact number of times. Your unit (KV-34HS420) has a built in self diagnostic software that will indicate the probable caused of the fault by flashing of the LED at the front panel.
Jdvillanueva
Nov 30, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony TV turns itself off after 5 second. The timer light blinks 7 times. It fixed itself for 2 days and then broke again
U know how to solders?Resolders the FBT,the flyback transformer.It a big block of plastic with a red wire with a cap hook to a CRT(tv tube).
Jan 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY TV MODEL kv-27s40 BLINKING RED LIGHT 2 BLINKS
The 2 blinks usually mea an over current problem. Perhaps the most common cause of this is a shortde Horizontal Output Transistor (HOT). If you can solder, you should be able to repair this yourself. Realize that there are potentially dangerous high voltages present inside the set even when unplugged. Look for a 3-legged ransistor attached to a heatsink close to the flyback (part with large red wire coming out the top). The part will be marked C5438 or something similar. Post that marking here nad I'll confirm the entire part number.
Keep us posted.
Dan
Feb 23, 2009 | Sony KV-27V42 27" TV
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony Fd Trinitron KV-32FX68E, stanby led blinks twice
odds are power supply module 150 200 repair
Dec 01, 2008 | Televison & Video
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron KV-32FS320 5 blinks
Sony KP53HS10 5 blinks
Five blinks means "Video out abnormality detection". Possible problem areas are as follows:
Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510, 516, 524 (A board).
There are actually three C boards, the CR, CG and CB boards. They are attached to the rear of the red, green and blue CRTs, respectively. I wouldnt attempt to repair the set myself. I would solicite the services of an authorized Sony servicenter.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-28FX60 28" TV Logo
220 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
