Icom Ic-718 100 Watts Hf Amateur Base Transceiver Ic718 Logo
Question about Icom Ic-718 100 Watts Hf Amateur Base Transceiver Ic718
Icom EP1 0910052045 PCB B 5381E looking for replacement internal magnetic rotary turning dial
Mike Charette
    Genius:
  • Icom Master
  • 1,847 Answers
Have you tried Icom
Posted on Jul 23, 2014
2answers
My Realistic DX-390 displays a "Door Key" symbol on the read-out screen. Can I eliminate this so that the radio functions?
Please see below. I believe that you have set the tuning to LOCK, hence the KEY symbol. I have done the same thing with other radios. I bet you never forget this!
Manual Tuning with Rotary Dial You can select a higher or lower frequency by turning ROTARY TUNING. Set FAST/FINE/LOCK to select the rotary tuning increments or to lock the ROTARY TUNING dial. The following table shows the tuning increments for the FAST and FINE settings. '------'------'-------'------'-------' ' ' FM ' LW ' MW ' SW ' '------'------'-------'------'-------' ' FAST ' 0.1 ' 9 kHz ' 9/10 ' 0.005 ' ' ' MHz ' ' kHz ' MHz ' '------'------'-------'------'-------' ' FINE ' 0.05 ' 1 kHz ' 1 kHz' 0.001 ' ' ' MHz ' ' ' MHz ' '------'------'-------'------'-------' To lock the ROTARY TUNING dial, set FAST/FINE/LOCK to lock. This keeps you from changing the frequency if you accidentally touch the dial. NOTE: This locks only the ROTARY TUNING dial.
1helpful
My machine starts to fill and then stops. It flashes 7 times. What is this error?
What is the Brand and model of your washer ?
Is it Indent ?
Many basic UK Indesit washing machines fitted with a rotary dial indicate error codes by clicking the dial continuously round and flashing the door lock light a set number of times.
If the door light (LED) flashes 7 times it means, "Heater relay stuck - check connections on heater and module (PCB)".
In my experience, this fault code usually required a replacement PCB and EEProm. A connection fault on the heater usually results in the entire washing machine going dead. Nothing will work, but the LEDs light up. This symptom can also be caused by an open circuit motor or other faults.
It's always possible for a connection fault to cause error codes but the heater relay is embedded in the PCB and if it develops a fault the whole board needs replacing. I don't recommend replacing the PCB as a DIY repair. It is an expensive part and it will not be guaranteed unless fitted by an engineer. New PCBs do not come with the micro-chip EEPROM which would also need fitting. Replacing the PCB and EEPROM yourself is risky. If the fault is not cured you cannot send the parts back.
If you have an engineer to replace the PCB and EEPROM I would imagine the cost is likely to easily be over £100. If your washing machine has a 5 year parts guarantee Indesit would supply the PCB free of charge but only if their own engineer fits it at a cost of about £90.
If you are really keen to fix this yourself and want to try another PCB there is a company that might be able to help and are happy to deal with the public called Quality Electronic Repairs (see link below)
How do i fix the rotary dial on canon t3
No, The top cover has to be completely removed, Then the circuit board has to be taken off to get to the dial, Then repair or replace it, Not an easy job. To get the top cover off you have to take the other covers off first.
Kenwood km-994 is to loud when volume dial is on low and will blow speakers if I turn it up
I'm no sure what you're asking. Do you mean that it goes directly from low to high immediately when you turn the dial(I'm assuming it has a dial, I haven't looked it up) or push the up or down button?
Answer is, if rotary, a bad rotary switch, or in both cases, a bad microprocessor or electronic volume.
1helpful
Is the Dremel 400 XPR unreliable or are the users expecting to much from the tool? I like the looks of the tool but I will probably end up with a 4000. I've been using a cordless tool but it keeps...
It's heating up and tripping the internal overload. They do that to prevent the battery from overheating.
The cordless are nice but they have limited applications
Please I have canon copier IR3170C but it has been giving me this error code E000021 - 0001 any time i on the machine and it is being boot. Please help me out. thanks
getfile.asp?rid=1258 May 8, 2006 getfile.asp?rid=3215 Product : imageRUNNER C3100 / C3170 Title : E021-000x Error Code Error :
E021-000x Error Code: Developing rotary does not rotate and abnormal noise comes from motor.
E021 can be displayed when an error occurs in the developing rotary.
The detail codes are:
0001: The developing rotary home position cannot be detected.
0002: The intervals of flag detection during rotation is too short or long.
0003: The sensor does not detect the flag when the developing rotary stops at development point
As a result of inspection, it was found that the DC Controller PCB was unable to control the motor because it was faulty.
Workaround :
1. Check whether or not the developing rotary receives any physical load.
Rotate the developing rotary in a counterclockwise direction by hand to see whether it rotates smoothly. If any abnormality is found, eliminate the root cause. No problem is found, go to the Step 2.
2. Make sure that the connectors are securely fitted between J313 on the DC Controller PCB and the Rotary Motor (M8) or there is no pinched wire. No problem is found, go to the Step 3.
3. Replace the DC Controller PCB with a new one. If the symptom still recurs, go to the Step 4.
4. Replace the Rotary Motor with a new one.
DC Controller PCB: FG3-3846-030
Rotary Motor: FM2-0080-000 Canon USA, Inc. Systems & Technical Support Division
2helpful
2answers
Ebrom(memory ic) number
try to find the service manual of the tv to locate the ic.these tv,s have the icom ic and the memory in a separate pcb.this pcb is a complete part.you must change all the pcb to solve your problem.the fault ic is the icom not the memory.
Hello
Push "Dial-I/U" and hold for 1 second.
Top Icom Radio Communications Experts
Robert McClure
Steve
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
