HP PSC 2210 All-In-One InkJet Printer Logo
Question about HP PSC 2210 All-In-One InkJet Printer
I cannot find the installation disk can I downloawn from intenet
My computer will not go on the inter net after i ran the restore disk
you might have to set up your intenet connection again which will mean setting up your modem/router again
hope this helps
How to down load yahoo messenger
go to yahoo>klik yahoo messenger> klik download now
you will download yM installer double click
klik next to all, wait until prosses over, note use intenet connection to install
I am trying to connect my old dell laptop to the intenet. I am using the usb port for the connection. When I put it in it says that i need to install the hardware but there is no disk. I have tried to...
Make sure that you are not running out of IRQ's. If you are running earleir windows like win98, you could be running out of if IRQ's. Win98 was bad about that. Try disable the printer and that should free up a IRQ for the adapter. If that doesn't there you go.
2helpful
Need a disk
try to donload your scanner driver from intenet in the company site
Laptop connectivity,site and cable driver
YOU NEED TO INSTALL ITS DRIVERS FROM A DISK THAT CAME OUT WITH IT AND HAVE A CABLE AS WELL.
WHEN YOU INSTALL THEM,IT WILL APPREHEND INTERNET OPTIONS AND YOU HAVE TO SUPPLY YOUR NAME AND ONCE DONE WITH ALL OTHER INFORMATION FILL UPS, AN ICON WILL APPEAR ON YOUR DESK TOP AND YOU JUST HAVE TO CONNECT YOUR PHONE AND DOUBLE CLICK THE ICON TO SURF. DO NOT FORGET TO LOAD AIRTIME ON YOUR MOBILE.
THANKS,
WONDER
Need restore disk
You should be able to contact the manufacturer to get assistance. Some laptops come with the restore information hidden on a part of the laptop. To make it work you will have to enter whatever keystrokes they direct you to use and the restore will automatically run. If you do need a specific cd, the manufacturer can also tell you what you need. Depending on the age of the laptop, you should be able to order it from them. If they no longer stock the restore cd's, you will have to get a copy of the version of Windows you want to install and install it yourself. If you are using XP or Vista, the cd should have most of the drivers you will need for the laptop. If not you should be able to track down the drivers on the Intenet.
Internet explorer aint working
try to reset the intenet exploere settings ...
Sometime the internet explorer settigns gets corrupted ....
To reset the internet explorer setting
(tools>internet options>advanced>reset)
1helpful
I neen a driver
Hmmm.. I am not sure where to find the drivers, or if the driver is a must. But if you have a driver file, then you can take it to any system and install it there.. Intenet connection is not at all required.
Ben Johnson
Marvin
Marvin
