Question about Danby Furniture
Sylvania wine cooler won't turn on - Danby Furniture
4 Related Answers
robert samples
  • 1314 Answers
SOURCE: Avanti EWC28 Wine Cooler TOO Cool
contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Posted on Jan 01, 2008
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
subdriver
  • 101 Answers
SOURCE: Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Posted on Feb 05, 2010
mrbobfixit
Robert DeStevens
  • 259 Answers
SOURCE: Are red wines stored on the top or bottom of the
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Posted on Jun 14, 2010
My U-Line mode l15BWC fan and compressor won't work
More than likely it is the temp control (thermostat) it is what controls the on and off
Oct 12, 2012 | U-Line Wine Captain (2015WC) Wine Cooler
Can I use my wine cooler to store other beverages?
The average wine cooler won't offer temperature below 46 Fahrenheit. Due to this fact you can store most of the light beverages in it but it is not meant to store this kind of drink. I suggest you to purchase a mini refrigerator in order to store your other drinks.
Aug 14, 2012 | Furniture
Should there be any problem to locate my wine cooler under the counter?
Actually, when using a freestanding wine cooler the heat designed to escape from the back and I your case the heat won't have a place to escape to and eventually will over heat the whole unit. Then the compressor will attempt to compensate for the heating and may eventually burn itself out.
How do I know whether a thermoelectric cooling system is better for me than a compressor?
This depends on several factors: how much wine you keep on hand, where you will be putting the cooler (cool/warm room in the house) and if you are buying a freestanding cooler/built-in. If you never have more than two cases, plan on keeping the cooler somewhere it won't get too warm and you want a freestanding cooler, you should look into purchasing a thermoelectric cooling system.
Jul 31, 2012 | Furniture
Uline wine refrigerator won't get cold
how old is it thay usely last a year or so set it tovery cold
May 25, 2012 | U-Line 15WC Wine Cooler
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
It just stopt cooling ([email protected])
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Wine cooler does not seem to cool below 14 degrees celcius
I have a Sylvania Electric Oven MODEL SM82500. The timer
has not been reliable for some time and I took the button to the store from were I purchased it as it is broken where it holds the shaft inside and they could not help me. I wonder if you be able to supply one. I really use the oven alot and would get the Timer Button.
[email protected]
Jul 06, 2009 | Weber Chill 05-161 Beverage Cooler
Sylvania table top wine cooler
go back where you bought it...buy another one and bring back the one thats flashing,get your refund and walk home with a new cooler
Jul 15, 2008 | Refrigerators
Dec 31, 2007 | Avanti EWC28 Wine Cooler
Furniture Logo
87 people viewed this question
Top Danby Furniture Experts
Dennis Boxerman
jdthefixer
jasbo
jasbo
Are you a Danby Furniture Expert? Answer questions, earn points and help others
