SOURCE: Paper jams
there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
you replaced the drum but you need to replace the toner as well (low toner)
then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
SOURCE: Lexmark E320
I am afraid to say that the fuser lamp has burned out this is replaceable part if you go to the link provided and go to parts you can get diagrams and the part # and ordering info from Lexmark
http://www.lexmark.com/lexmark/site/home/0,6932,204816596_0_0_en,00.html
best luck
SOURCE: SE Menu for Lexmark T640
Its a two key combo. Try the following;
Press and Right arrow and menu together and power on printer OR
Press and Right arrow and GO together and power on printer
SOURCE: lexmark x85 paper jams
I have owned several X73, X83, and X85 printers. Most of them end their life in the way that you are describing your problem. They will start by feeding the paper thru the primary load but will not feed the paper thru to be printed on and out the paper exit.
First and foremost, I advise you to unplug the printer, remove the flip top cover and turn the printer upside down and shake. I have seen items in the paper path such as a penny cause issues like this. Also make sure the paper path is clean and no small tears of paper in the way that could be blocking. If you find something check again, hopefully this is the good solution.
If that does not work, it is most likely that you need the print engine for the unit. Unfortunately this costs about $109 if you can find them (unless they got cheaper since I last checked).
If it makes you feel any better I have one that matches your's on the shelf here :) You can get a new AIO printer for $109 or just a little more.
SOURCE: i need a manual for lexmark lase printer t640 or
Firs, yes the T630 will contain most of the information you are looking for. Obviously, it will not cover the features of the T640.
Did you check the downloads section on www.lexmark.com For the publication you need.
What information are you looking for?
Don
