Question about Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803
Correct way to change time on tag heuer aquaracer quartz watch
5 Related Answers
Anonymous
SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
Posted on Mar 17, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I own a tag heuer
Yes it is correct as your watch has a counterclockwise crown forward setting direction. This is due to the specificaly layered lever and setting gear construction, so, nothing wrong with your watch.
Do not forget to rate, please.
Posted on Jan 27, 2009
Anonymous
  • 11 Answers
SOURCE: Dont know how many time to wind it
until it begins to feel just slightly taunt,Do NOT over wind a wind-up wrist watch, if its a self winding you should just have to walk in it to wind it. here is a link to a pdf of your manual which has winding procedures, Good luck Jon click here
Posted on May 21, 2009
Anonymous
  • 19 Answers
SOURCE: What type of swiss quartz movement is in a tag
ETA or F0 movements are usually tags number 1 choice of movements.
ETA G10.711
Posted on Jul 14, 2009
If the stem does not lock in, will it still be waterproof?
You need to get out your jeweler's loupe (best at 5x & 10x)... and look for the threads to "*****" (ski-rue) down your winder-stem (not a lock).
(Features a Ski-rue down crown & back case)
YOU can pretty much be assured that if the "stem" collar is malfunctioning (broken) the "water-proof" element is compromised (that's most likely the least of your troubles).
More importantly... if the STEM does not properly "tighten" it can
cause further damage against gears which MUST align with it... further it can come all the way out and be lost... Not an inexpensive part.
Best direction would be to get it serviced by an authorized agent.
TAG Heuer Aquaracer 500M Quartz Mens Watch WAJ1110 BA0870
TAG Heuer Aquaracer WAJ1110 BA0870
Jaxa style Suissetek XL Wrench Case Opener for Large Screwback Watches
Mar 30, 2016 | Tag Heuer Aquaracer Quartz WAJ1110.BA0871...
Tip
TAG HEUER Aquaracer quartz chronograph manual.
Follow this link and download original TAG HEUER Aquaracer quartz chronograph manual: http://www.tagheuer.com/the-collection/aquaracer/man/quartz-chronograph/index.lbl?w=CAF1110.BA0804
on Feb 09, 2010 | Watches
The winding knob does not lock when I press and turn
That means you need a new stem. Stem problems are fairly common on Quartz Tag Heuer watches. Should not cost you more than $100.
Nov 10, 2013 | Tag Heuer WAF2110.BA0806 Aquaracer...
I have a CAN1010 TAG AQUARACER CHRONOGRAPH and whe reset it the second arm doesn't reset to 0 but instead stops 2 seconds before..
This works! Loosen the bezel all the way. Pressing the bottom button, press one time the topmbottom and see how the chrononhand corrects by one second towards zero. Do it again and have it reset. Tighten the bezel. Thats it
May 13, 2011 | Tag Heuer Aquaracer Quartz Chronograph...
I have an ct1115 tag heuer aquaracer chronograph and the caps to the buttons on the side fell off easy fix? you can push them with your nail the watch still works etc. the covers are gone
The pushers sound like they have fallen off.This is quite a common problem.Take care as the watch wont be waterproof.The parts will need to be obtained from TAG and fitted by a watchmaker.Return the watch to an agent for them to attend to or find a watchmaker that can get TAG parts.
www.rolexrepairs.co.uk are specialist watchmakers that could help.
Regards
Aug 04, 2010 | Tag Heuer Aquaracer Quartz Chronograph...
What type of swiss quartz movement is in a tag heuer aquaracer waf1010 ba0822?
ETA G10.711
Jul 13, 2009 | Tag Heuer Watches
My Aquaracer Automatic doesn't keep exact time
you bought a automatic watch, they are a quality time piece, not an acurate time piece. if you want acuacy buy a cheap quartz watch.
Apr 07, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch.  Change the battery, and see if the problem goes away.  If it does not, then it could be a problem with the stepper motor, which will require a watchmaker.  Of course all of this is dependent on the assumption that your watch has a quartz movement.  If it is an automatic, or mechanical you have bigger problems.
Oct 19, 2007 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag Heuer Aquaracer Quartz Chronograph CAF1112.BA0803 Logo
75 people viewed this question
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
