Question about Faby Cab S.p.a Faby CAB Frozen Drink Machine 2 Bowl
Repair slush machine repair men
jasbo
  • Faby Cab S.p.a Master
  • 2,239 Answers
Try allen associates in rochester, ny.- allenprograms.com
Posted on Nov 30, 2014
I have a sunsip slush machine and is not freezing, and machne is running for nearly 6 hrs
if the mix is cold but not freezing, you may be low on refrigerant or the timer is in defrost (if it has that feature). if it's warm, either the solenoids are not opening or there is no refrigerant. check the exhaust. if there is little air flow, clean the condenser coils (air intake). if it's cold, the compressor is not functioning or no refrigerant. for low or no refrigerant, you have a leak. take it in for repair
Jul 21, 2014 | Kitchen Appliances - Others
My slush machine is tripping out
pleae explain further. is the overload tripping? tripping circuit breakers? just not working right? also, what brand of slush machine?
Jun 22, 2014 | Kitchen Appliances - Others
Left side of Bunn Ultra "ice" mode is in lower case but right side "ICE" mode is in upper case?
upper case means it is still trying to slush. lower case means it has reached designated slush thickness
Jun 15, 2014 | Bunn Margarita Machine Ultra 2 Slush...
Ugolini slush machines
you need to replace the gear bushings in the auger motors. or if they're no too bad, you can just flip them and get more time
Apr 06, 2014 | Kitchen Appliances - Others
What causes_slow_freezing_in_slush_machine
check the airflow. if the condenser coil on the left side is clogged with dust, it won't chill. remove the side, clean the fins, and try again. also check the fan. if it's not moving very fast, replace it.
Apr 12, 2013 | Bunn Margarita Machine Ultra 2 Slush...
In slush machines, how come the slush does not get completely frozen?
slush is made from sugar and water bonding together. the sugar is used as an antifreeze and then the mixture is constantly spun by the machine in order for it not to freeze.
Jan 24, 2013 | Kitchen Appliances - Others
Looking for gear in gear box in Slush Puppie machine ?
open the back top cowling (2 screws), remove motor assembly (4 screws
Jul 02, 2011 | Bunn Margarita Machine Ultra 2 Slush...
Lost manuel for slush ease machine
go to bunnomatic.com, find your machine and go to publications, you'll find all the manuals. Then just print. The maint. manual is 168 pages.
Aug 17, 2010 | Bunn Margarita Machine Ultra 2 Slush...
I have an Ultra 2 bunn slush machine. One hopper
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
May 22, 2010 | Bunn Margarita Machine Ultra 2 Slush...
Need instruction booklet/for slush ease machine
http://www.nostalgiaelectrics.com/manuals/HSM-250.pdf
this is for the nostalgia electrics slush ease drink maker...
May 20, 2009 | Bunn Margarita Machine Ultra 2 Slush...
Faby Cab S.p.a Faby CAB Frozen Drink Machine 2 Bowl Logo
665 people viewed this question
Top Faby Cab S.p.a Kitchen Appliances - Others Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Faby Cab S.p.a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
