SOURCE: i was using my blender and it suddenly stoped
1 check for burned fuse .
2 often the brushes that are in contact with the inductor get worn you have to replace them ( 2 brushes).
jrico39
SOURCE: replacement jar for hamilton beach wave 50754 blender
Check out the www.goodmans.com. The company is out of Florida and they do not charge sales tax outside of Florida. They have a variety of blenders for sale as well as blender parts. I hope this will help you.
SOURCE: Hamilton beach blender cleaning - food underneath
Usually the ring on the bottom of the jar unscrews. There is a rubber gasket beween the jar and the bottom hub holding the cutters.
Make sure you reassemble it correctly.
SOURCE: HB model 52735C type B35..intructions for blender pls
I'm trying to find a replacement Blade for my Black & Decker BL675 nut i'm having a really hard time finding one... Any suggestions?
SOURCE: how to change clutch in Hamilton Beach blenders
You need a screwdriver and soft hummer. Secure the screwdriver on one teeth of the cluch and lower the screwdriver to have un angle of around 60 degrees. Now you hit a little fast the scredriver with the hummer in order to unlock and unscrew the clutch. Then it will be easy to unscrew with your fingers. This is a litle bit triky so you may need to try some times in order achieve it.
Please remeber that you it unscrew reverse than it rotates.
The new one need only to screw in place and it will lock by itself as soon as you will use the blender.
Good Luck
