Question about KitchenAid Refrigerators
I have a Kitchen AId refrigerator model KSRB22HF. It tripped the circuit breaker...repair man replaced defrost timer...Refrigerator ran for about 30 hours then tripped the breaker. Repair man returned and replaced the defrost thermostat. Refrigerator ran for about 30 hours then circuit breaker tripped. Repair man says buy a new refrigerator he's not coming back.
Posted by peng46391 on
JonSnell Electronic
    Top Expert:
  • KitchenAid Master
  • 31,830 Answers
Probably the best thing to do unless you paid a lot for the attempted repair.
Posted on Aug 18, 2017
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: Freezer and refrigerator run but is not cold
Andeb, couple of things you want to check. Is the fan in the freezer section running? Take the lower back panel off and see if the condensor fan is running as well as the compressor. As long as you tilted it only slightly I would think this is a fan or overload relay problem. Check the things I mentioned and post back...Catriver.
Posted on Aug 21, 2006
douglas smith
  • 1462 Answers
SOURCE: Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
Posted on Jun 19, 2007
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 01, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Posted on Sep 06, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: Kitchen Aid model KSRJ25CNST00
HI. your unit is equipped with a defrost thermostat that is wired directly to the control board/PCb, and linked to the defrost element as well. this thermostat has failed, in return, not allowing the proper transfer of correct temp readings that the control uses to calculate the proper defrost cycle.
Replacing the defrost thermostat(Bi Metal) will fix this issue.
Trips power when timer clicks to defrost mode
is possible that your defrost element is shorting out to the body of your refrigerator it's also possible that you have too many items plugged into the same circuit as the refrigerator and when the defrost comes on it draws a lot more amperage .and trips the breaker
Appliance 911 Sea Breeze
Aug 19, 2015 | Jenn-Air Refrigerators
. I have a Kennmore Coldspot Fridge that runs for
A 15A circuit is mainly reserved for lighting.
Even some vacuum cleaners would trip a 15A circuit breaker.
The problem isn't with your refrigerator...its with the breaker installed in the breaker box.
Check your wire size and follow these rules :
12 gauge wire can have 30A c/b max
14 gauge wire can have 20A c/b max
16 gauge wire can have 15A c/b max
So, if the wires coming out of the wall socket is 12 gauge or even 14 gauge...you should be able to swap that 15A circuit breaker with a 20A circuit breaker.
This should be plenty for your refrigerator...if it "pops a 20A"...then you've got appliance problems.
If you don't feel comfortable doing that...then get a new 15A breaker...because it sounds like the other one has gotten weak.
Hope this helps
Jul 23, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New defrost timer on fridge keeps tripping circuit breaker
The problem is the defrost timer you just replace on your refrigerator, you will need to check the ratings on the broken defrost timer to ensure it matches the ratings on the present defrost heater on your refrigerator, beside, you will need to test the continuity on your present defrost heater to see if the voltage rating is ok, because, if it can be tripping the breaker off while it kicks into defrost mode signify that the present defrost heater is not compatible with your refrigerator, it is either it is not well wired or fixed, and if it is, then, it means the defrost timer voltage rating is low compare to the former, you will need to get exact specification as the the broken one.
Take care.
Jul 10, 2010 | GE Refrigerators
Kenmore fridg pops circut breaker,
Sounds like a shorted heater. You advanced manully, unit runs till timer goes to defrost. Timer contacts switch, defrost heater shorted trips breaker.
Apr 04, 2010 | Frigidaire FRT21P5A Top Freezer...
Fridge never stops
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 11, 2009 | Kenmore 53082 / 53084 Side by Side...
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
My Whirpool Refrigerator tripping the electric supply in regular intervals inspite of all electrical intallations are okay
Unless there is a dedicated circuit of 20 amps to the refrigerator this will continue to happen When your refrigerator goes into defrost and other things like lights fans air conditioners are on the same circuit it will have no choice to not trip the breaker. Try this turn the breaker off and how may thing in your house stop working? You need a 20 AMP circuit or this will possibly damage the compressor or weaken the breaker because it has tripped so many time. Thanks, Please rate my solution, I have done this work for 30 years. Thanks, Sea Breeze
Aug 27, 2009 | Whirlpool ES5FHAXS Side by Side...
Fridge keeps tripping the circuit breaker
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Jul 10, 2009 | Whirlpool ES5FHAXS Side by Side...
Refrigerator tripping ground fault circuit
The thing you were "spinning" was the defrost timer, not a circuit breaker. The problem may be you have a shorted defrost heater; It is on a timer that runs it for 30 minutes every 8 hours of compressor use.
May 31, 2007 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
171 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
