Driver
SOURCE: Will nthe sidewinder precision pro work with XP?
yes you need version 3.0 or later for it to work.
SOURCE: combat flight simulator
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
SOURCE: drivers for windows vista 64 bit
I am sorry, but I have to tell you that the Sidewinder II is not Vista 64 bit compatible.
Here Microsoft page for Vista compatibility, when they say unknown it means it does not work on Vista 64.
I hope this can save you some time.
SOURCE: Microsoft Sidewinder Force Feedback Pro 2 Drivers
You should be able to download them from the Microsoft web site.
SOURCE: Lost the manual for sidewinder
Honestly no manual is even needed and I don't believe they are even readily available on this old of a game controller. If you have a specific question or trouble I am sure I could help you. The device should just be plug and play. Although you will have to set up the games individually to use it.
Thank you,
Lee
