SOURCE: I have a print cartridge
Hi ptgraphics
Had a quick look at the cannon web site and the supplies and accessories for both printers are the same.
Yes you can use the cartridge. If you want to double check follow these two links.
IPF5000 http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SNAModelSuppliesTabAct&fcategoryid=860&modelid=14005
IPF5100 http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=180&modelid=15275#SNAModelSuppliesAct
If you are still unsure contact teh supplier where you ordered the cartridge and ask them to exchange it for you.
Regards
Go-Tech
SOURCE: Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
SOURCE: canon ipf 8000s
Over heat of the print head.
Turn off - Turn on the machine, if this will not work try to access the service mode update to the latest firmware version and replace the print head
i have downGrade firmwares for IPF8100,IPF9100,IPF8000, IPF605,IPF700 UNLOCKS PRINT HEADS WHEN THE PLOTTER ASK YOU TO CHANGE THE HEADS. mail- [email protected] for questions and support
