Question about Nokia N72 Cellular Phone
N72 hang and memory full - Nokia N72 Cellular Phone
1 Related Answer
bnty
bnty
  • 61 Answers
SOURCE: My nokia n72 keeps on saying memory full.....
hie!
if ur cell is displaying the memory full warning, it means ur phone memory is full, try to reduce some software frm the phone memory, and always install the softwares on ur memory card whenever it ask to install the path, while installing a software.
if the problem is still there, of memory full after emptying ur phone memory, then soft format ur cell, by pressing *#7370# and then the security code(12345 by default)
bt before that backup all ur important datasuch as contacts and mesages of the phone memory, as then soft format reset all the settings and flash all the phone memory.
bunty
Posted on May 03, 2009
I have problem in my nokia n72 mobile it shows memory full,now i am unable to see call logs, mssage etc i have already deleted all the files ,messsages ,memeory card data from my phone. please help me
The phone seems to show that the memory is full as there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jan 25, 2011 | Nokia N72 Cellular Phone
My nokia n 72 get hanged very frequently
1st try and update the software of your mobile from a nearest service center.If it doesn't work then check the size of the memory card installed in it.Most handset have their compatibility with the size of external memory u may input,but when it exceeds it starts hanging.Normally N72 has 2GB of external expandable memory.Please check this solution.
Dec 17, 2010 | Nokia N72 Cellular Phone
N72
just dial the below number
if it ask for phone code type 12345
#*7870# resets the phone settings to default.
#*7370# full reset
use these method hard reset
2) Press these 3 keys simultaneously: CALL key, ASTERISK key (i.e. *), THREE key.
first remove your memory card
(note all your data ill get lost )
please rate me
Mar 30, 2010 | Nokia N72 Cellular Phone
N72 hangs
the memory is bad
Nov 27, 2009 | Nokia N72 Cellular Phone
I forgot the password of my Nokia N72 and can't restore it to factory settings. It has got it's phone memory full too, so when I do anything on it, it hangs and I have to remove it's battery and restart it...
if u hav forgot your passs word then restart your mobile and then connect to pc suit and crack your password or you can format your mobile ,your all phone memory data will lost bur your pasword will become as by given mobile set
Aug 15, 2009 | HTC Tilt 8900 Smartphone
Hanging problem
Friend, try to check if your memory is not full. be sure it has enough memory to aviod slow process
Jul 10, 2009 | Nokia N72 Cellular Phone
N72 hanging probleh
release some memory then it will b opened
May 26, 2009 | Nokia N72 Cellular Phone
I have a problem with my Nokia N72 cell phone it is not displaying anything just a white colour is displaying"
nokia n72 has a slow operating system which gets even slower if the battery is low and thw problems are doubled if the memory is near full. Sometimes unsupported applications hang on it which can only be stopped by removing the battery and restarting the phone.Restarting may take a lot of time but have patience and once the phone restarts delete the application which caused the hanging. An advice is to keep the memory card half empty.
Mar 20, 2009 | Nokia N72 Cellular Phone
My memory card files are unable to access
i want to put 1 gb memory card tomy n 72 is it possible and it is really working good or goes slow or it get hangs
Nov 12, 2008 | Nokia N72 Cellular Phone
N72 hangs after starting..
does the phone work without the memory card?
Aug 18, 2008 | Nokia N72 Cellular Phone
Nokia N72 Cellular Phone Logo
64 people viewed this question
Top Nokia Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Zaid Anarwala
Zaid Anarwala
