Question about Locks & Locksmithing
How to reset combination for Nu-set padlock model 4397?
Posted by Gots Tago on
Grady Turner
    Scholar:
    New Friend:
  • 101 Answers
How to reset combination for Nu-set padlock model - 337aef22-51ba-41e7-a034-4cfa8ce964d8.jpg
You'll need the reset tool, as shown in the picture.
Posted on Jun 23, 2014
  • Gots Tago Jun 23, 2014
    Yes, I contacted NuSet directly via email. They replied to my email with-in two hours and sent me the tool at no charge. Great customer support!
    Thanks for responding to my post. Maybe it will help someone else.
1 Related Answer
Tingno
SOURCE: how to reset a sterling 101c combination padlock
How to unlock you phone with out own code
Posted on Sep 30, 2011
How to Reset t tsa lock on a Mia toro luggage
How do I set a Mia Toro luggage lock? - Fixya
www.fixya.com/support/t26581106-set_mia_toro_luggage_lock
Apr 30, 2017 - Release the reset button after you set the numbers to the new combination. ... If you still can't open the lock, contact Samsonite Customer Service at .... TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to ...
Amazon.com: Questions And Answers: How do you set the luggage ...
https://www.amazon.com/forum/-/Tx1WRFLRQIYMJR0/ref=ask_ql_ql_al_hza?asin... Jun 20, 2016 - Mia Toro Metallo Composite Hardside 26 Inch Spinner, Blue, One Size ... The factory setting is 000 make sure lock is set to this press the reset ...
How to Set A Luggage Lock / LuggageFactory.com - The Travel ...
https://www.luggagefactory.com > ... > How to Set A Luggage Lock Sep 10, 2014 - TUMI: TSA Combination Padlock: Make sure the combination is set back to (0-0-0), the factory setting if new, or the existing combination if it has been used already. Make sure the mechanism is unlocked. Press and hold the button on the side of the lock. Select a new combination.
how to Reset tsa lock on Mia toro luggage Google Search
Jul 26, 2017 | Locks & Locksmithing
What's my combination
Each padlock has a different combination. If you lost yours, that's reall bad luck. Take it to a good locksmith, maybe he can find out. If pretends to charge you too much, get a new padlock
Apr 12, 2015 | Master Lock 175D Combination Padlock...
How do i reset a yale series 150/30 padlock
this step by step guide should help you reset the lock, if its not the exact same lock, its the closest thing that Yale currently makes. Be aware you cannot reset locks like these unless they are open already, atleast not to my knowledge
Combination Cable lock Reset the combination of Yale travel lock Secure...
Jun 06, 2014 | Yale Y150/30/125/1 Combination PadLock
How do you reset the combination to a Ace Solid Brass Combination Padlocks
Open the lock, rotate the shackle180 deg, and push down.enter new combo, and rotate shackle back to normal position.
Mar 27, 2014 | Ace Hardware Ace Solid Brass Combination...
Master code for brinks padlock
the lock combination is not working anymore, I can not open the lock, how I can reset the new combination
Sep 04, 2012 | Brinks 1-1/2 In. Brass Combination...
How to unlock samsonite combination lock?
1. Call Samsonite Customer Service at 1-800-262-8282. Representatives are available Monday through Friday from 10:30 a.m. to 5:30 p.m EST.
2. Press "1" and then "6" on your telephone keypad to speak with a representative to order a replacement key or padlock.
3. Pay the required fee. Samsonite will then send out the replacement key.
Aug 17, 2012 | Samsonite Tsa Acceped Padlocks Allow You...
I've just purchased a Tri-circle 40mm 4-digit padlock (model ZB40). The combination is set to 0000 but there aren't any instructions. How can I reset the combination please ?
Instructions nowadays are often found online. Check the company's site, or contact their customer service, also found online. They can walk you right through it, need be.
Aug 29, 2011 | Locks & Locksmithing
Lost combination to nu set lock box . I would like to open the box and be able to reuse it.
You can dial all the combinations (1000) in a couple of hours while you watch TV. I just did one (2012 version with letters) and hit about half way through. The problem is going to be a lack of a key. You won't be able to open the shackle on some versions and won't be able to reset the combination (same key for both functions).
Nov 20, 2009 | Locks & Locksmithing
Locks & Locksmithing Logo
392 people viewed this question
Top Locks & Locksmithing Experts
john h
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
