When system runs for a long period of time it eventually freezes up
SOURCE: Air conditioner line freezing up
Check to make sure the filter inside the air handler is clean and that no vents are closed or blocked by furnature or rugs. Check the air handler to see if the blower is operating. You could have a belt off, the door switch could be in the open position or something simple like that. If this checks out OK., you will need to have a technician check the charge
SOURCE: air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
SOURCE: my air conditioner lines keep freezing up.
You have a blockabe in the distributor tubing which will need a professional to sort out.
