Hi Friend, thank you for your question!
I understand you would like to know how to unlock the door of your Frigidaire oven. May I please have your model number? You can typically locate the serial tag (which lists your model number) inside the storage drawer, on the right side. With this information I can provide you the correct instructions. Thank you! - Z
Posted on Jun 10, 2014
SOURCE: oven door won't unlock
I posted a message on 12/27 and since then I have contacted Jenn-Air again and as I mentioned above the two things they told me to do didn't work, so I looked at the schematic of the unit and there appears to be a motor that locks and unlocks the door. I have a service repair coming this Saturday and seems to believe the motor is bad. Trenatru are you getting an error message? I was told by Jenn-Air that there is a 6 yr. warranty on electrical parts so will try to keep you posted if that is the cause. If you havn't tried shutting off the power try that first. They said keep it off for a couple minutes before turning back on. If that try pushing on the door and hitting cancel twice. If those two things don't work, will let you know what I find out next weekend.
Posted on Dec 31, 2007
SOURCE: Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Posted on Apr 12, 2008
SOURCE: slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
Posted on Jan 23, 2009
SOURCE: frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
Posted on Jul 25, 2009
SOURCE: The Oven is a Frigidaire
Hi!!
It wont hurt to try to reset the Electronic Clock Control by disconnecting power to the unit for a couple of minutes, connect it back up and check operation. If problem still present, Check the latch/lock motor, door latch, oven temp. probe and all wiring specially at the terminal block (see diagram for component picture and location) if it OK, most likely the problem is on the electronic clock control (aka EOC). Replace it
The part number for the EOC is AP2125564, this board costs about $200, you may want to try the following link to have your board re manufactured for a fraction of the cost. http://www.appliance411.com/links/jump.cgi?ID=769
Here are the break down diagrams for the Frigidaire range Model FEF365BGWC
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=110576&diagram_id=242946#d242946
Good Luck!!
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 04, 2010
Hello friend, thank you for your post!
Based off the information you have provided you need to know the location of the speed bake switch inside of your Frigidaire oven. I would be happy to provide you with that information, if you can provide me with your model number. You can locate the model number on the serial tag and that can be found on the bottom drawer frame. Once I have that information I would be able to assist you further. -Matt
