First be sure the valve is in the on position. sounds crazy but I've been there. Next even though the pilot is lit it may not be burning hot enough to make the Thermo pile produce the 750 millivolts the valve needs to operate. If the thermo pile is producing the proper current then the gas valve itself is the culprit. If you are not comfortable with gas and do have the proper testers You should call a pro. The pilot is easy to clean though. turn the gas valve to the off position and remove the pilot. When you remove the gas line to the pilot there is a small oriface inside that looks like a little thimble. Remove it and clean it. the gas flows through a very small hole that clogs very easy. Reassmble it tighten the gas line. Check for leaks with some bubbles and give it a try.
