Question about Nespresso C190 Espresso Machine
Ejector replace broken ejector
Replace cylinder 4 fuel ejector
That means you need a new injector.
Apr 18, 2014 | 2005 Cadillac CTS
Fix broken ejector handle
You need to obtain a replacement flash ejector handle first. If you open the router out, you can push the broken ejector handle out with a small flathead screwdriver, it just slides out forward toward the face of the router if you apply a bit of pressure. Then you just slide in the new ejector handle, which is "keyed" on one side. There is also a small metal lever pin that you need to line up with the spring hole when sliding the new ejector handle into place. Once inserted is will snap gently into place and you are done.
<a href="http://www.ciscobuy.com">Sell Used Cisco Equipment</a>
Mar 15, 2012 | Cisco 2801 Router - 2801
13 years old; water dispenser works fine -- refuses to make ice cubes
Your icemaker module is likely broken. Look at the ejector fingers and see if they are pointing up and slightly to the right. If not, replace module.
Kelly
Mar 24, 2011 | KitchenAid Refrigerators
My playstation 3 disk will not go inside the playstation, it seems to be blocked, i have a fat playstation 3, if you could help i would be very greatful! Thanks!
Seems like the disc ejecting mechanism is broken...or if u have taken it apart recently, the sensor tab for the ejector is in the wrong spot..if u took it apart, do it again and make sure the little metal tab in the shape of an upside down "U" is in the proper slot and moves freely...if u didnt do anything to it then u seem to have a broken drive ejector and need a full new blu ray drive...sorry but these are 100 bucks but r easy to install and only take 15 mins and a few screws..try ebay for a warrantied one..hope it helps.
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
My ice maker is not dumping the ice it just freezes and stays in there help
You need to replace the ice maker . It is a lot less time consuming to replace the ice maker , than to try and repair it . But , if you want to try , you have a bad thermostat , or broken gear . If the gear type , pull the cover off the ice maker , and you will see the motor running ( small gear ) , but not turning the large gear . In this case , replacing the large gear , would be the best thing , instead of replacing the whole ice maker .
Nov 21, 2009 | Admiral Refrigerators
Whirpool Icemaker
Pam, if the ejector blades are in the 2:00 positon then it's in it's home position. When you open the freezer door, you should see two flashes followed by a pause repeatedly. Hold the left side emitter down and the light should stay on steady. If you have this, the optics are good. Next step is to remove the ice maker from the mount and inspect the module. Make sure that the two clips that are holding the center wheel are not broken, If you only see one clip, then it's broken. If that is ok, make sure the fill tube is not frozen up, they have a habit of doing that. If it is, use a baster and thaw it with hot water. If that is ok, leave the ice maker on the top shelf with the harness attached. Unplug the refrigerator and insert a jumper between T&H. Close the freezer door. Plug the refer back in and wait 50 seconds. Now open the freezer door and see if the ice maker is cycling. You may have to press the light switch 3 times. If it is cycling it will call for the fill when the ejector blades are at 12:00 high. If it's doesnt cycle, try it again. Sometimes this takes up to 3 times to get it to cycle. If it fails to start after 3 attempts and the optics are good, replace the module. Let me know how you make out. Catriver
Jul 01, 2008 | Refrigerators
GE PSS26 NGP Ice maker
Hi Vadim, You should have a steady light showing on the ice maker. If the lead is flashing, it's either a thermistor failure or ejector not home. The reasons why the ejector blades will not home is because of a magnet failure, control board failure or a stalled motor. The feeler arm could also be sticking. The control board contains 2 sensors that are activated by magnets. One magnet is attached to the end of the ejector arm to determine whether the ejector blades are at home. The other is located on the ice sensing arm, lets the control know whether the arm has reached a fully extended position. In a lot of these, I find the magnets broken. I think you can save yourself a lot of trouble by just replacing this ice-maker. Catriver.
Dec 28, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker
Look at the ice maker and see what position the ejector bar (white bar with fingers that turns and ejects the ice).  Looking at the ice maker from the front (front is white plastic cover) the ejector bar should be in the 2-3 o'clock position .  If it is not then the module is broken.  In this case the module and ice maker thermostat need to be replaced.  If not sure how to do this repair then just buy a new ice maker.  Let me know what you find and we can go further if necessary.  This is the first thing to check.
Oct 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Ice maker gear tabs RS25AGXNQ01
not worth getting a repair kit for the gears, i reccomend purchasing the entire ice amker as a whole, replacing just the gear wont correct the reason that it craked in the first place
Feb 19, 2007 | Roper RS25AEXLQ Side by Side Refrigerator
Nespresso C190 Espresso Machine Logo
91 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
NOEL
NOEL
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
