SOURCE: Setting tax rate on a canon P170-DH
To set the tax rate, slide the "GT" switch to RATE. Enter the tax rate (i.e., 4.5 for 4 1/2 %). The display should show 4.5 %. Slide the "GT" switch to OFF.
SOURCE: Setting Tax rate
First, you have to make sure the calculator is set to two decimals. Then push the tax+ button, push the rate button. Now push the rate you want the tax ON, then push the rate button. If you want 2%, make sure to set the rate at 2, not at .02
SOURCE: Canon p23-DH V
Slide the on/off switch all the way to the left to the "Rate Set" position. Now enter the appropriate tax rate. When entered, slide the switch to the desired "On" or "Print" position and CE/C before your first calculation. You should now be all set to go.
SOURCE: CANNOT SET TAX RATE ON MY CANON MP11DX
To change the tax rate on the Canon MP11DX (and most others):
Slide the "GT" button to "RATE", enter your tax rate and hit the "TAX+" button. Once changed, slide the "GT" button back to the "ON" position.
SOURCE: Settting up tax rate on Canon P1-DH III
push CA
hold TAX+ button until tax% starts flashing on the display
put in the required rate
push CA
should now be set
