Question about Life Fitness Exercise & Fitness
How do I remove the console on the treadmill?
I need to move the Spirit Life Fitness treadmill into other room and the console makes it to wide to fit thru the doorway. please help me.
1 Related Answer
Anonymous
  • 11 Answers
SOURCE: Get Life Fitness 9700 generation treadmill through doorway
You need to remove the upper console arms/assembly - unbolt the five or six large bolts holding the frame to the base (you will need to remove the motor hood) and unplug the cable from the circuit board that goes up inside the arm to the console (make sure the power is unplugged!) use a 3/4'' ring spanner or socket.
Posted on Apr 27, 2010
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
Which treadmill should I get?
Dear Sir, all depend how much do you want to spend
Guide from some friend, relative or some nutrional instructor.
God bless you
Oct 18, 2012 | Life Fitness T3 Treadmill with Advanced...
My treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
May 04, 2012 | Life Fitness T3 Treadmill with Advanced...
Moving nordic track 2750a pro too big to fit
Dear Sir:
You have the alternativa to fold the treadmills, and get help for another persons.
Please see the user manual from Life Fitness, and see the section how to fold the treadmill, and ready.
If you do not have the manual, go www.lifefitness.com see the customer service, go parts&manual, give you model and download for free. or to www. searsparts.com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua
Feb 15, 2012 | Life Fitness 9700 Next Generation...
Stuck Key Error Message on Life Fitness F3
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
May 03, 2010 | Life Fitness F3 Folding Treadmill with...
I need to remove the console on my treadmill in order to move it to another room - can you give me a run down on how to disassemble that part? thanks, Diane
Hi Diane
Look underneath with a flash light the electronic console has on each side 2 allen bolts holding the console to the up rights.A cable is also going into the upper display first must be disconnected by gently prying off that console cable cover. Remove the bolts I believe with a 6 mm allen wrench and that should do it. reverse that order when reassembling.
Apr 12, 2010 | Horizon Fitness 725T Merit Fitness...
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
Sep 01, 2009 | Life Fitness 9700 Next Generation...
I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Aug 29, 2009 | Life Fitness T3 Treadmill with Advanced...
Exercise & Fitness Logo
19 people viewed this question
Top Life Fitness Exercise & Fitness Experts
Vincent G
Vincent G
Thomas Perkins
Thomas Perkins
gbob59
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
