No power to fridge, even the light not on but fuses ok
SOURCE: RLA30 Fridge freezing food on lowest setting
From the symptoms ,I would recommend that you have a new thermostat fitted.
This is the cheapest option., fig's do not go wrong that often
Any comment welcome.
Thanks and a merry xmas.
SOURCE: Swap door sides on hotpoint future RLA30 fridge?
tip unit over on side,placing an old blanket or similar on floor under unit.there are 3 little bolt/screws holding each bracket to the underside of unit,unscrew these/lay brackets on floor, slide door down off pin on underside of top.and unscrew this pin.change over from right to left replace door onto pin replace bottom hingepin,adjust door for" squareness " and tighten all screws lift back upright and switch on...will take a little time to settle down temp wise.... make sure seal sits tight all round good luck ..geoff
