Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
I have a hotpoint aquarius+ WD640 the control panel is flashing 02 it goes through cycles and wont stop bought a new control pannel its still doing the same can anyone help???
Bought a recondition control panel and its still not working can anyone help ???
  • Dai Boyce
    Dai Boyce Nov 15, 2014
    Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores.
mmgm
    Problem Solver:
  • 14 Answers
Check the carbon brushes of the motor. And then press the button start for about 5 sec. until all leds lights up.
Posted on Jun 06, 2014
1 Related Answer
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: hi i have a Hotpoint WD640 1400 spin Aquarius +
The dryer fan or dryer thermistor (thermostat) is faulty.
If the fan is working, then replace the thermistor, or check for broken wire.
Please rate my solution.
Thanks.
Posted on May 19, 2009
1helpful
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
MY WASHING MACHINE STARTS A WASH CYCLE THEN SUDDENLY STOP AND STARTS FLASHING F-02 WHAT DOES THIS MEAN?
Hi.
Error code F02 is a problem related to the motor.
It means that the motor is jammed, or tachco detached.
Check connections on motor and module, and motor plug.
Thanks.
1helpful
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Hotpoint Aquarius WMA46 1300 , front loader
half loads will vibrate more than full load
check transit bolts are removed
if vibration persists, then fault is probably shock absorbers worn
Aquarius
i have the same problem if you find out please let me know...... think may need a new program for machine would be cheaper to buy new one all together
Hotpoint Aquarius WD440
u might have a blockage in the drainpipe. hope it helps. good luck!
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
Paul Carew
Vernon Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
