Question about Suburban Gas and Electric Water Heater, 12 Gallon SW12DE
I am trying to get my hot water heater to turn on, using the propane, when I turn the switch on inside the RV there is no clicking noise coming from the hot water heater. Also the red light next to the inside switch does not come on. I have propane flow because I can light the stove.
Could be your igniter or possibly your control board. The red light not being on indicates you most likely have an electrical issue. Check your breaker as well. If you nee any parts this site will have them all
http://www.suburbanrvparts.com/
Posted on Mar 01, 2018
SOURCE: How do I check my hot water heater
Do you have a meter? You can use it to see if you have power and if there is a problem with the thermostat. If not then it would be best to have it looked at by someone at an RV center.
Posted on Jun 06, 2014
Apr 20, 2016 | Water Water Heaters
Jul 15, 2014 | Water Heaters
Jun 05, 2014 | Suburban RV Hot Water Heaters 10 Gallon...
Aug 08, 2012 | Water Heaters
Feb 16, 2011 | RTO Atwood Water Heater - 6 Gal LP
Jan 08, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Oct 10, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
May 25, 2010 | RTO Atwood Water Heater - 6 Gal LP
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
Mar 31, 2009 | Water Heaters
323 people viewed this question
