HELP
SOURCE: dropped a WD passport drive, now it won't load. HELP!
Unfortunately, these drives are not made to be dropped.
It sounds like it was damaged by the drop which could have rendered the read/write heads inoperable or mis-aligned.
Contact Western Digital for a warranty replacement.
SOURCE: WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
SOURCE: MY WD PASSPORT IS MAKING
Dear luis6987,
Try to replace the cable or plug in to other port.
regards,
dm
SOURCE: my wd passport essential se
I would return the Western Digital Passport Essential SE back to were you purchased it. Exchange it or get your money back. It is defective sounds like.
