Question about Lexmark X4650 InkJet Printer
How do you change the language setting on a Lexmark E460dn?
DocZachary
    Master:
  • Lexmark Master
  • 533 Answers
Http://publications.lexmark.com/publications/pdfs/2007/e46x/v14844198_en.pdf
Here is a link to the manual.
Good luck.
Semper Fi,
Z
Posted on Feb 18, 2018
1 Related Answer
brett207
brett207
  • 231 Answers
SOURCE: how can i solve this problem? 935.10 service
This is a service error, which will need a technician to diagnose and repair.
Probably a faulty laser scanner assembly.
Posted on Dec 07, 2009
Lexmark E460dn paper stuck
If the paper is stuck on the fuse, I am assuming you mean the fuser. You will probably have to replace the fuser. You can remove the fuser and try to remove the paper and then reinstall the fuser. Could be a sticky sensor as well.
Apr 12, 2014 | Lexmark E460dn Laser Printer
Lexmark E460DN Laser Printer
Hello it would be easyer to download the driver here:
http://support.lexmark.com/index?locale=EN&page=product&userlocale=DA&productCode=LEXMARK_E460&focusedTab=DOWNLOADS#1
And uninstall the old software, and install the new.
You just have to select your windows system.
Or go to: The manual can be found here ( In pdf )
http://www.lexmark.com/publications/pdfs/2007/e46x/v14844198_en.pdf
You will need adobe reader, to read the content.
Look at page 100.
Best of luck
Feb 01, 2013 | Lexmark E460dn Laser Printer
When I choose default to letter size in Lexmark E460dn printer, it bumps to legel, asks to load legal paper and then prints 3/4 page. I do not want to print in legal size. I want it to stay at letter.
Please try to check the your drivers settings. The settings set on your driver will always override the printer settings. Please click on the link below, this will show you how to create custom size forms or paper size. http://bitly.com/nVAsX1 If you need further assistance please contact Lexmark Technical Support.
Sep 22, 2011 | Lexmark C533DN InkJet Printer
I am getting an error on my Lexmark E360dn printer. It states 31.05 Replace defective or missing cartridges. Please advise what the possible issues may be.
Please click on the link http://bit.ly/q5DVho to see instructions on how to go about the procedure.
For additional assistance, please contact Lexmark Technical Support
Jul 21, 2011 | Lexmark E460dn Laser Printer
How to change language
If you are referring to the display language, you may use printer's operator panel to change the display language
1 From a Ready status message, press Menu. The menu names appear.
2 Continue to press and release Menu until you see the Set up menu.
3 Press Select to select the Display language on the second line
4 Continue to press and release it until you see the correct language and press select to select the correct language
You may also do restoring factory default settings.
For further assistance, please contact Lexmark Technical Support.
May 25, 2011 | Lexmark T630 Laser Printer
My language on my printer is in German i need to change to English wondering if i could purchase a manual for my kexmark all in one printer model # 3350
No need to purchase one, lexmark offers an online version of the user guide on their website here:
http://www.lexmark.com/publications/pdfs/2007/3300/winug/eng/frameset.html
Interestingly enough the User's Guide for the X3350 contains the wrong instructions for changing the language on the LCD display. The correct way to reset the language is as follows:
1.Power off the printer.
2.Hold down the power and + buttons simultaneously for five seconds. This will clear the language setting.
3.The first prompt you will see is English. If this is not the language required, toggle the + and - buttons to navigate to your preferred language.
4.Press the arrow button to select that language. The printer will save the new language setting.
Hope this helps!
Please rate this solution, thanks
Mar 14, 2011 | Lexmark Office Equipment & Supplies
Change language on display screen of lexmark x3350
Here's an article in the Lexmark website on Wrong Language on the LCD Display of the Lexmark X3350. This article shows you how to change an incorrectly set language on the printer. Just click on this link: http://bit.ly/aMhhLr. Hope this helps.
Jul 11, 2010 | Lexmark X3350 All-In-One InkJet Printer
How can i solve this problem? 935.10 service printhead error lexmark E460dn
Dec 07, 2009 | Lexmark E460DW Mono Laser - 38ppm, 466MHz...
Lexmarkx73
On the printer or on the program?
The program included can help you change the settings on the printer itself.
Go to the printer properties within Windows then to Printer preferences by right clicking on the Lexmark printer, look for language and set it to English. Press ok.
Dec 15, 2007 | Lexmark X73 All-In-One InkJet Printer
Lexmark X4650 InkJet Printer Logo
235 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
