Westinghouse DW39F1Y1 39in Class 1080P LED HDTV Logo
A
Anonymous Posted on Jun 05, 2014
Westinghouse flat panel television problems
Can't get digital channels. in setup menu there is an DTV option but it won't allow me to select it. please help.
2 Related Answers
Chi Chu
  • 8457 Answers
  • Posted on Sep 12, 2009
SOURCE: Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Anonymous
  • 2098 Answers
  • Posted on Jul 31, 2011
SOURCE: Westinghouse flat panel with DVD
Please let me know the exact model no. of your unit, it will help diagnose where the fault came from.
Also, confirm first the status of the signal from your cable provider, try to hook up the cable wire to another TV to determine if the signal is not the issue here.
Jdvillanueva
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
(OSD)
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Is this model digital or do I need a top box set
Ian a model number and the make / Manufacturer would be helpful
If you use the select source on the remote control if it displays DTV as a source then it should do digital once you tune the television in - you may have a channel autoscan option in the menu options most likely and you may even see it scan for DTV channels !
2helpful
We have just received a new toshiba 32BV500B LCD tv. We did the initial installation but after the analogue channel scan the digital channels have disappeared and we cant find a way to get them back. How...
Hopefully, if you were to press the menu button and somewhere on the screen will be DTV. Select DTV and then you can run search again.
Hope that makes sense.
How change setting to received a digital signal. Look like TV is in Analog mode. I put a coverted BOX and see TV without any problem but without converted Box, I see a white screen with noise. TV Model:...
U want free air DTV?Yes,have a good Digital antena or a roof antena hood up to ur tv.Goto the tv menu.Goto SETUP go down to Ch.setup enter and pick AIR not CABLE.Enter it again for scanning for DTV free air channels.After done the scanning u should have all the free DTV free air channels.
1helpful
Hdlcd19wb series a - How do I get the channels in digital, rather than analog? I can't even click on the "dtv signal" option in the menu. All the channels listed to add or delete are analog.
Put the HDLCD19WB on a channel. Press menu on remote. Select channel on the sceen. Press enter on remote. Select auto channel memory on the screen. Press enter on the remote. Use the right arrow button on the remote to set the signal type to air for antenna or cable. Select automatic search on the screen. Press enter on the remote. Wait for search to finish. Check channels with the channel up and down buttons on the remote.
If you have any digital channels you should have them now.
The dtv signal option in the channel menu is only available when tv is tuned to a digital channel.
2helpful
2answers
My LCD won't tune into DTV
You need to go to your menu option with your remote. Select channel scan from the options listed in setup. This will allow the turner to find your DTV channels again. Hope this helps. J
Scanning dtv channels
go to menu setup and do the full system reset setup option... Then before you scan for channels make sure it is set to cable... This fixed the problem for me.
DTV locked on ITV1
do a reset in the service menu the turn the tv off and press..
info>menu>mute>power on
and go to the reset option. don't mess with any other setting in this engineer menu.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
