Question about NorStar M7310 Phone
Restricted call nortel t7316e how can remove the restricted
My phone model Nortel T7316E '0" press shows restricted call how can remove this
5 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Need to divert T7316E Nortel to mobile phone
I can help, but this is a free forum. Your installer is your best bet, but on a short notice, here's a manual for a CICS. Follow this link and grab it.
http://public.carl.airpost.net/
Denied in Admin means it's restricted. Remember I noted that there are programming and Class of Service issues. If you can get into Administrative programming, you can follow the Terminals and Sets link to find Redirection. IIRC it has to be allowed per set. Let me know when you get this, as I won't leave the manual online for very long.
Carl
Posted on Dec 11, 2008
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: MY NORTEL T7316E, THE OPERATOR
Try FEAT #85. Somehow I'll bet someone was playing with the buttons and dialed FEAT 85. It needs the # to cancel.
Posted on Jan 09, 2009
consultel1
george peters
  • 860 Answers
SOURCE: How do i set up a voice mail greeting on my nortel phone?
bodell,
The short version of getting to your greeting is:
Feature 981 or open voicemail key
your password
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
hope that helped.
Posted on Feb 09, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: T7316e Nortel Meridian Norstar Telephone MANUAL
Not too sure what type of manual you are looking for, but here is a useful link to have for a Norstar system information.
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Posted on Mar 25, 2009
consultel1
george peters
  • 860 Answers
SOURCE: I have Nortel T7316e phone
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Press the release key when finished
Posted on Oct 01, 2009
Where is the show key on the nortel T7316 phone
Not sure what you mean by Show key but if it's to check what the buttons are programmed for, you do this:
-press Feature button (strange satellite/orbit button above the Off Hook/Pick up red button on right)
-press *
-press 0
-then press button you want to check
If that's not what you are looking for, give more details what you want to do
Jun 11, 2014 | Nortel T7316E 2-Line Corded Phone
Restrict calls
Is this on NOrtel or IP Office? Which NOrtel system?
Apr 26, 2013 | NorStar T7316E Corded Phone
I can't log into my Nortel vm account
Change the administrator password by pressing Feature 985 dial 9 even though it is not listed as an option. The display will show Pswd: dial 73738767793. The display will show Reset pswd? Press YES. Now you can log into the voice mail system administrator using Feature 983 and the password 1020000 if you have 3 digit extension numbers. Add or delete the 0 between the 1 & 2 depending if you have 2 digit or 4 digit extension numbers.
Sep 17, 2012 | Nortel Networks T7316E Telephone Platinum...
Denied access on Nortel T7316E Log# 1020000 will not work..How do I fix this?
Follow this instructions to reset the Administrator password.
Press Feature 985 and dial 9 even though it is not listed as an option.
You should now be able to enter the default password.
2 digit extensions use 120000
3 digit extensions use 1020000
4 digit extensions use 10020000
Jul 31, 2012 | Nortel Networks T7316E Telephone Platinum...
My MBOX is locked on my T7316E Nortel phone. Also, trying to retrieve messages from home I somehow changed the password and I don't know what it is.
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you your mailbox extension
Apr 25, 2011 | Nortel T7316E 2-Line Corded Phone
How do I remove Denied in Admin from a Nortel phone handset
You don't. Only the administrator who set that restriction can undo it.
Mar 11, 2011 | Nortel T7316E 2-Line Corded Phone
Why wont red Message light on my Nortel Phone
more than likely someone in your office left the message rather than the voice mail. to clear it press the call soft key below the screen. the screen should display who left the message with two of the soft keys labeled call and erase. press the erase soft key. it's possible the the person/s that left the message left multiple messages. in that case repeat the procedure til all messages are canceled
Jan 13, 2010 | Nortel T7316E 2-Line Corded Phone
Change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
Mar 17, 2009 | Nortel T7316E 2-Line Corded Phone
How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Mar 11, 2009 | Lands Phones
Nortel T7316E, How to make headset work ?
Look in the System coordinator guide 5.0 for HandFree
Select type of handfree
You must set the Handsfree at: auto
Its in the deep programming
Your going to need Business Series Terminals programming overlay to put over the phone.
  1. Press Function **266344
  2. Than enter system coordinator pass word
  3. Press SHOW once and enter your phone extension number
  4. Press SHOW twice
  5. Press NEXT tree times
  6. Change the parameter at HANDFREE with MOD
  7. Set it at AUTO
I beleved this will FIX it OK!
Jan 28, 2009 | Lands Phones
NorStar M7310 Phone Logo
257 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
