Sanyo DP42849 42 in. HDTV Logo
Question about Sanyo DP42849 42 in. HDTV
Can you replace a cracked lcd on a sanyo dp42849 42 inch tv
Boards are all fine, do you know anywhere thar sells screens or should i try and buy the same tv thats broken because of bad boards and trade all the boards out
Posted by logansedergr on
Andrew Lohbihler
    Master:
  • Sanyo Master
  • 505 Answers
That's a good idea. Screen replacements are not easy to match with any TV. But boards are usually compatible with most TV's of the identical make. You should check that an identical board has the exact same version number too to be compatible.
Posted on Jan 02, 2015
5 Related Answers
Anonymous
SOURCE: Wanted: 32" Sanyo LCD replacement screen (compatible)
take apart the lcd and find the lcd panel number then email [email protected] to buy a new panel from a factory in china
then put it all together
Posted on Apr 17, 2009
Anonymous
  • 1077 Answers
SOURCE: Sanyo DP15647 powers on but no display, trying to find fault
I had a similar problem like yours with a different TV. I had to find the Service Manual for the TV to really find the problem. The manual gives me every schematic and parts number list for every board in the TV. It turned out to be a bad Inverter Transformer. It was one of six that powered the LCD screen. You might have the same problem.
The Service Manual on the internet for most TVs are under $20. It's the best material for diagnosing the problem. It worked for me.
Posted on Jul 15, 2009
Chi Chu
  • 8457 Answers
SOURCE: Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 02, 2010
Anonymous
  • 1961 Answers
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
Posted on Jun 04, 2010
Anonymous
SOURCE: i have a 47 inch sanyo lcd tv and the screen is
i have a 47" inch lcd sanyo t.v. and my kids accidentally shot it with an air-soft gun. and there is a crack where the pellet hit and there is also a crack running down that spot. Also the screen has these lines running up and down the screen. Different colors. and i was wondering if it was possible to fix.
Posted on Jan 19, 2011
Need sanyo 42 inch hd lcd screen replacement
they have a few panels over at tv repair world send them a email [email protected] they may have one let them know your model number.
1helpful
DP42647 On half of our 47 inch screen it is black and distorted when we first turn the TV on but after 30 or 40 minutes it finally just lights up and is fine.
Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish board that call the T-CON board for the replacement.This board sit in the middle at the bottom of the LCD screen panel.This T-CON board only job are to decodering picture pixels dots only before it show up to the LCD screen panel.
We just recently had a power outage and I think it may have fried my television but I'm not sure what is actually fried. I can plug it in and hit the power button and the green light on the front blinks...
I have the exact TV. Mine works just fine but the screen is cracked. I can't find a replacement screen anywhere. I would be glad to either buy your screen to replace my broken one or I could sell you the circuit boards from inside mine for $50.00. And you can just replace your boards with some that work. You can reach me at [email protected] I live in the Houston Area. Email me with your number and I'll call you.
1helpful
I need a new panel screen for my 55 inch vizio model number vf550m. The part number is lc550wudSBA1 I believe. how much am i lookin at for buying that? i cant find anywhere online that sells them. my...
Sorry u out luck,no where u will able to buy the LCD screen panel,the only place u can buy a LCD screen panel is at the Vizio tv Corporation itself.The tv LCD screen panel are limited in production.They'll sell it to u,but they'll charge u the same as a new tv.Tries trade the tv it in with the Vizio tv Corporation,u can get like 10% or 20% off toward a new tv.That all u could do.Or u only can sell the tv that have a crack sreen panel tv for it electronic boards for parts that it to get some money toward ur next new LCD tv purcharse.
We recently moved and this tv must have been damaged in the process. Although, the exterior looks fine, when we tried to turn it on the picture was a complete mess! It appeared shattered with colors sort...
Buy a new tv.The tv u have now,the LCD screen panel it internal screen membrain is broken.The tv,u have now,dosen't worth a whole tv anymore.Tv only now,worth as only as a salvages tv for it electronic boards for parts,that it.The LCD screens panels are 90% important to the LCD tvs,when,that damages or broken.The tvs doesn't worth it to replaced it LCD or Plasma screens,because tvs screens panels are limited produced by the tvs industries,u will not able to buy it anywhere,but the tvs industries themselves.They'll sell it to u,but the same priced as a new tv.
I have a 46 inch sharp laid it on the corner of my radio it put a crack but i still have a little picture can it be repaired
No,LCD screen panel is damage or broken can't be repair only can be replaced the LCD screen panel.The tvs LCD screen panels are limited production buy the tvs industries and 90% important to the tvs.U can't buy these tvs LCD screen panels except from the tvs industries themself.They'll sell it to u but charge u the same prices as a new tvs.Sorry the tv now,does not worth as a whole tv anymore.Only worth as tv for salvaging for electronic boards for parts that it.
1helpful
I have a 47 inch sanyo lcd tv and the screen is broken in the lower right hand corner i want to know how much it will cost to fix and i dont want it will be cheaper to buy a new one
42helpful
11answers
I have a Sanyo 46 inch flat screen hdtv purchased from walmart aug. 31rst, 2008. Sure enough, 13 months later my tv is having picture problems and getting worse. It started having portions of the screen...
I have the same problem, my television is faded black on the left side with lines on the left top side. I have had the 46 inch unit for 1 year and 7 months. I am planning to write a demand letter to Sanyo and then taking them to small claims court woth evidence that this is a common problem with their units that they know about and is not trying to remedy. Also the Attorney general in Texas should have an interest in them (Walmart and Sanyo) selling these defective proucts in the state.
1helpful
Broken and cracked 42' sanyo lcd tv, the screen is all yellow, orange and can see all of the cracks throughout the tv, can it be fixed and how much if possible?
Unfortunately it is not, The cost of the screen is just as much if not more than a new tv. Sorry to be the bearer of bad news, but in our shop we have seen may sets broken with the WII and it is a very sad day for our customers. Warranty will not replace a cracked or broken screen.
There might be a small silver lining to this though, the boards in your tv are valuable for repair purposes. It is possible that you could sell the boards through e-bay to make up some of the loss, but you must list the correct part number. That is how people will search for boards, we have done this before and we have purchased boards for brands we normally don't work on.
38helpful
8answers
CRACKED LCD PANEL Vizio GV42L 42 in. LCD
Try to find new screen on amazon here Amazon com vizio 42 screen replacement. Hope this was helpful. cheers
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
