I have reversed the hinges and followed the manual guide but i don't see any way for this to work unless i can pop out the shelves and flip them. there are no holes on the opposite side of the doors for the hinge pins to set into. does this require drilling holes approx 5/8 dia and then moving the nylon guides?
SOURCE: Fridgidaire side by side door popping follow up : will this work?
duuuuude, i have the same problem with my kitchenaid. please help if you get any anwers!
Leroy in Dallas, TX
SOURCE: my frigidaire door shelves broke... how to get them fixed cheap?
Order them from the sears.com website.
SOURCE: can the door be reversed
Look to see if you have bolt holes on the opposite side, if so you can usually change the swing. Sen us a picture and we'll let you know.
SOURCE: it is a replacement hinge kit for the bottom of my
It is best to seek for the original part/ component as you do not have to make any alterations on the fridge.
please check on the link below for tips on spares.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Thank you for your inquiry, Sterling Calhoun!
From the information you have provided you would like to reverse the door swing on your Frigidaire washer. I have reviewed the manuals for your washer and I was unable to locate any directions on reversing the door. If you need any further assistance please feel free to reconnect. -Matt
Hello paulascor549 - I completely understand that you took the oven door apart to clean it, therefore you must have took the following steps to do so. According from my research you would have to reassemble in reverse order. If you have already tried to do so and it proves to be ineffective, contact a professional to move forward accurately.
Door Removal and Cleaning of Interior Glass
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide? With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
