Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck Logo
Question about Sony TC WE435 Stereo Dual Cassette Deck Single Dual Cassette Deck
How do I dub using the onyx double cassette deck?
I don't have a Sony. I just picked up a used ONYX double cassette deck and am wondering how to use the dubbing feature. I have not succeeded in getting both cassette mechanisms to work at the same time, although the record light goes on. Do I have to press to buttons or even more at once to dub a blank tape from a recorded one?
Grubhead
  • Sony Master
  • 5,750 Answers
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Posted on Jul 25, 2014
5 Related Answers
Anonymous
SOURCE: will not dub another tape
This site is useless. It tells you nothing.
Why does it exist?????
Posted on Mar 29, 2008
Anonymous
  • 38 Answers
SOURCE: Dule cassette dubbing
No sir,
you can not dub a tape on single cassette deck, unless you have another cassette deck.
ramesh22
Posted on Jun 09, 2008
Anonymous
  • 1512 Answers
SOURCE: Repairing or replacing old tape decks
Hi m522posner
There is a surprising interest in "vintage" hifi products these days. Your tape machines probably needs new belts. Check this site out. You can get spares for your tape machine here. Belt kits are $17. He does repairs also, but the transport to and from may be an issue for you. I suggest emailing Bob, he may be able to refer you to someone in CA > I could do the repairs,but I am in Australia. :)
Vintage Electronics
P.O. Box 941
1241 Conestoga Creek Rd
Florissant, Co 80816
Email: [email protected]
You could have a go at freshening up the belts yourself:)
regards
robotek
Posted on Jul 12, 2008
informatica
Greg Cann
  • 1114 Answers
SOURCE: WE475 Sony Dual cassette deck
Hi - You can download the manual from the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 27, 2008
Anonymous
  • 10 Answers
SOURCE: Just bought a used Sony TCWR610, to reproduce some
I have the same tape deck. To do a copy on this machine you first press the normal speed button below synchro dubbing, then hit the pause button on the recording side to start the copy. It will automatically start both decks.
And to stop the recording hit either of the stop buttons.
Posted on Jan 13, 2011
2answers
How do you dub cassette to cassette
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
How do I turn on an onyx mp3 player
First, make sure that the Mach Speed Trio Onyx MP3 player is fully charged (if you use a rechargeable battery) or insert a new AAA battery. Then press and hold the Play button for 5+ seconds. This will turn off the MP3 player if it is on.
Retrevo has the manual for the Onyx here: http://www.retrevo.com/support/Mach-Onyx-2GB-MP3-Players-manual/id/2831dj281/t/2/ . You will need to enter a code to access the PDF.
I hope this helps.
2helpful
Ho do i use the high speed dubbing feature to quickly transfer tapes to my pc using the alesis Dual-Cassette Tape Digital Archiver?
What's your hurry? You copy a tape once but listen to it forever in real-time without fear of it wearing out or degrading. Shouldn't it be as faithful a copy as you can get?
Downloads here:
http://www.alesis.com/tapelinkusb#
A little advice.... if you have any desire to transfer the higher frequencies from your cassettes to your digitized copies, do it at normal speed. The hi-end response of the deck is ok at normal speed but doubling it will double the playback frequencies, making incapable of reproduction with any fidelity.
Frequency Response
(-20dB recording)
Chrome tape 40-15000Hz (±3dB)
Normal tape 40-14000Hz (±3dB)
(0dB recording)
Chrome tape 40-8000Hz (±3dB)
Normal tape 40-8000Hz (±3dB)
Imagine what its response at, say, 30000Hz might be. That's what doubling the playback speed would demand from the head and electronics. It ain't hi-fi anymore.
Just bought a used Sony TCWR610, to reproduce some valued cassettes. Cannot get the B deck to record. There is a little red light that comes on that says REC, but deck does not turn as I start the tape...
Onyx on Linux
I have seen most of the mp3 player works with linux.
Problem downloading music
yea you go to i hate onyx.com than you click on this thing sucks.then you go **** your dads ****
Unable to to dub from the radio, phono,or cd
As far as I know, you need to press Record button to record from external source. If you press Dub, it will start Dubbing from Tape-A to Tape-B. You might be need to press Record and later press Pause or Play to start recording.
No sir,
ramesh22
3answers
Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
