Question about Chevrolet 1996 Chevrolet S10/s15/sonoma Radio
What is the posible cause 1996 chevy s10 code p1351 can old gas cause this problem
Runs untill it warms up then it backfires and stales when i hite the accelerator
Posted by richard wheeler on
  • Chevrolet Master
  • 18,402 Answers
This is not old gas. There is a whole section on it for you to follow here: http://www.hotrodlane.cc/New%20LS%20Links%20Page/LS%20trouble%20codes/DTC%20P1351.htm
Posted on Jun 06, 2014
My 1995 chevy s10 idols fine until engine warms up. Given gas it lugs down and dies. Changed fuel pump&filter,tps,cps,oil pressure switch,Vaccumm lines. Had it scanned. All that showed was bad relay.
You will need to have the computer scanned and monitor the data stream to see what is happening. The 02 sensor info will let you know if the engine is over/under fueled and what may be causing it. Throwing parts at it by just guessing gets expensive. The data stream, if viewed by a trained technician, will reveal any problems that may be causing your problem
Jan 20, 2016 | Cars & Trucks
On a 92 Chevrolet s10 c/k 4.3litre TBI fuel injection pickup,,what can be causing loss of power wenpressing on gas? Otherwise,it run great.
Chevy S10 - GMC S15 and Sonoma Stalling/Dying Problems - Car ...
forums.edmunds.com > Chevrolet > Chevrolet S-10
Dec 15, 2007 - 30 posts - ‎22 authors please someone..i need help.i have 1992 gmc sonoma 4.3 6 cyl 2wd .... I have a 2001chevy s10 4.3 4wd auto, it runs good until it's warmed up, then once it's ... the gas pedal causes bouncing on the tachometer and loss of power. ... when driving at a steady speed if I try to accelerate the engine tries to die
Sep 24, 2015 | Chevrolet Cars & Trucks
1996 s 10 code p1351 any ideas what causes this
Possible causes - Faulty Ignition Control Module
- Ignition Control Module harness is open or shorted
- Ignition Control Module circuit poor electrical connection
Jun 05, 2014 | 1986 Chevrolet Chevy
1996 jimmy goes to limp mode after it warms up gives 1886 code
drop the catalytic converter and test drive. It could be clogged
Mar 17, 2014 | Chevrolet 1996 Chevrolet Blazer S10/jimmy...
My chevy s10 pickup 2.2l sputters amd backfires even blew out muffler i have tried everything i can think of whats wrong
The timing chain and gears are probably worn causing late valve timing. This will cause backfires, and flames out the intake. I'm guessing this is a high mileage engine.
Jan 22, 2014 | Metra Chevy S10 t10 Pickup, Gmc Sonoma...
1989 Chevy S10 loses power and backfires
A large vacuum leak is likely the problem. Could be the intake gaskets. If you have power brakes, are they working ok? If not, suspect the booster diaphragm has failed. Is the pcv valve in place? Any vacuum hoses not connected?
Jun 13, 2017 | Chevrolet S 10 Cars & Trucks
I am getting code p1351 on a chevy s10 it will not start could this be the timing chain
No this is not a timing chain
P1351 CHEVROLET - Ignition Coil Control Circuit High Voltage
Conditions for Setting P1351:
The voltage on the ignition control circuit exceeds 4.9 volts, and the engine speed is less than 250 RPM.
Bottom line?
Most likely its a bad Ignition Control Module.
Mar 28, 2011 | 1996 Chevrolet S-10 Pickup
1996 chevy silverado has hard time starting. Put it on a computer and it told me (p1351 ignition control, circuit voltage high). What do i need to do to fix the problem?
Check the connections at the vehicle control module
(vcm) located on the left fender. Check for bent-broken pins or pins that have pushed through the plug
Make sure the connections are tight and dry.
Do the same at the coil. Also check for any exposed
or shorted wires between the two. Hope this helps
Mar 03, 2010 | 1996 Chevrolet K1500
1996 chevy s10 heater not blowing hot air
heater core or leak on cooling system
Jan 06, 2009 | 1996 Chevrolet S-10 Pickup
Chevrolet 1996 Chevrolet S10/s15/sonoma Radio Logo
114 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
