Epson Stylus  CX6000 All-In-One InkJet Printer Logo
G
Gillian Cormack Posted on Jun 05, 2014
I have epson stylus sx215 printer error code w-11 can you help
I have changed ink cartridge as it said needed replacing now it's saying cartridge not recognised
5 Related Answers
Anonymous
  • 121 Answers
  • Posted on Apr 28, 2009
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Anonymous
  • 428 Answers
  • Posted on Mar 24, 2010
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Goldi Kunal
  • 187 Answers
  • Posted on Sep 30, 2010
SOURCE: How to Change ink cartridge
#1 Wait until you are out of ink. The warning light and ink-low notifications come on well before the ink cartridge is empty, and even if it runs out of ink in the middle of a print, you can replace it then and finish the print with no problem.
#2 Lift the lid of your Epson inkjet printer to expose the ink cartridge replacement button. Make sure you have plenty of light so you can see what you are doing.
#3 Press the ink cartridge replacement button. This will loosen the empty ink cartridges so they can be pulled up and out.
#4 Fill the empty cartridge at an ink-refilling location, or buy a new ink cartridge to replace the empty one.
#5 Insert the new or refilled ink cartridge into the holder with the same orientation as the previous one.
#6 Press the cartridge replacement button to charge the system and close the printer cover. Charging takes about one minute
Thanks
Anonymous
  • Posted on Jan 21, 2011
SOURCE: how do i change the
press: INDEX SHEET and SCAN both at the same time, use two fingers if possible.
Your epson monitor Screen should show: NOZZLE CHECK and below that a left and right arrow with 1/6 between them. using the right hand arrow key just below the monitor, scroll through to item 4. then press the green start key to get the carriage ink holder to move into change position.proceed .
Anonymous
  • Posted on Feb 22, 2011
SOURCE: Epson Stylus SX215 the ink cartridge holder won't
its because the ink housing will only aline when the ink is empty its not like any other printer that you can line the housing up. Wait until you run out of ink then lift up the lid and the housing will be alined - its stupid system and epson dont tell you this when you buy the produc
Have just installed new ink to my Epsom Stylus sx215 but wont print, just blank pages
Ensure cartridge fitted 100%, and you have taken off cartridge protectors, but the Printer should tell you why it's not printing !
sound simple to replace ink cartridge, but it can be tricky.
s
2helpful
How do I change the ink cartridges on an EPSON STYLUS Sx215
Hi joanmcd2, Just go to control panel and go to (printers for xp)/(device and printers win 7) open the properties of the driver and goto Maintenance tab and then click the EPSON Status Monitor button, you will see the ink levels and there will be an option to replace the ink.
for details pls dwonload the Sx215 manual on this link
Printer (epson stylus sx215) wont recognize generic ink cartridge
- try to repeat a remove and replace all cartridge. with the careful and pass.
- if it does not changed, try to reinstall driver,s
good luck .......
How do i change the ink in my epson stylus sx215?
  • Select "menu" and "setup mode"
  • Select "maintenance" and "change ink cartridge"
GOOD DAY
BOBUS
1helpful
I have bought epson sx200 ink instead of sx215 will this still work as if not i will have to return it unopened???
Just have a look at the generic cross reference chart for aftermarket ink jet cartridges & you will see the one cartridge suits ten different Epson models
BLACK >>> T0891 Compatible; Ink contents 19ml
Stylus S20, S21, SX100, SX105johncsuk123
Stylus SX200, SX205, SX215
Stylus SX400, SX405, SX415
13helpful
3answers
I have a new epson SX215 and have lost the manual.I cant figure out how to replace the ink!! Help needed quickly please., Anne Cunningham
Hi Switch on the printer give a print job and open the panel the head comes to the centre and then you can remove.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
