Question about INTEX Sand Filter Pump
I do believe that intex sells a kit to vac the pool ,it includes a plastic scoop that fits in skimmer to go to bottom vac wand
me i saw a photo of kit and made one out of an old vinegar container i cut the bottom off of and a length of old hose from a wet /dry vac and i use that to run around bottom to suck up solids (gotta fill hose first before connecting it )
Posted on Sep 13, 2014
SOURCE: my intex sand filter is
You have a broken "lateral". You will have to remove the sand from the filter, find and replace the broken lateral (pipe with slots in it in the bottom of the filter). When you are ready to refill the sand, put enough water in the filter to cover the laterals (several inches actually) to avoid damaging them as you fill.
Thanks for allowing me to assist you this evening @ FixYa.com
Posted on Jun 22, 2011
SOURCE: Leaky Leaf Filter On Intex Sand Filter
Hi thevideowatc
Check your o-ring seal to make sure it doesn't have sand under or on it, also it may have cracks in it, or the filter may have cracks in the housing...if that is so, then replace the housing.
Bud
Posted on Apr 14, 2013
on Aug 03, 2013 | Pool & Spa
May 10, 2016 | Intex Pool & Spa
Jul 09, 2014 | Swimline Hydrotools Sand Filter
Jul 05, 2014 | INTEX Sand Filter Pump
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
Nov 02, 2012 | Intex Automatic Salt Water System for ...
Jun 16, 2012 | INTEX Sand Filter Pump
Jul 31, 2010 | Intex Automatic Salt Water System for ...
110 people viewed this question
