How many times have you entered wrong code on your Nokia C7? Nokia phones has only limited attempts. Don't waste the attempts with wrong code. Better visit Unlock-Zone.Com to get the accurate unlock code for your Nokia C7 at affordable cost with easy unlocking guide. Good luck.
SOURCE: my nokia 2730 was locked
Just follow the steps
Make a backup of massege and contacts in your another sim.
Soft reset( factory setting)
On Sybmian phones:
*#7780# - Restore factory settings
*#7370# - Reformat your phone (back up your personal data with PC Suite or to the memory card first!)
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate and leave a short comment,that is your choice.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
