SOURCE: I have a Kenmore Elite Electric Range Model #
Hello, welcome to FixYa.
I understand you have the Kenmore 7904671 range, correct ? I also understand based on your post you're getting the F11 error message, correct ?
This range is built by Electrolux/Frigidaire as you may or may not know and according to the service manual, here's what it is and what you can do
...I will also add, Fault codes are not a foolproof system. Never assume that a part has failed based on a displayed fault
code.
("TST" is the touch sensitive panel and EOC is for Electronic oven control or timer)
...If you pull/slide the unit away from the wall and unplug it or turn the house breaker off for 30 seconds to a minute the control should reset. That should do it...unless either of the control's has failed.
Let me know how you make out and if you need anything further I'll be glad to help in any manner I can. Good luck.
Regards,
Macmarkus :)
SOURCE: Kenmore gas range F11 error code
The "F11" fault code indicates a shorted button on the electronic oven control. This means the oven control board will likely need to be removed and replaced. You could disconnect power, wait 30 seconds and reapply power. If "F11" returns upon power-up, replace the electronic oven control board (EOC). but if i had your model number i could nail it right on the head with a fix...
F11 = control board failure
The power surge during the outage damaged the control board and it will need to be replaced. Here is the board to order.
Testimonial: "Thanks!"
