Lexmark X1150 All-In-One InkJet Printer Logo
Question about Lexmark X1150 All-In-One InkJet Printer
Lexmark printer ribbon cable
Ribbon cable
Ink installation issues
Here's an article on the Lexmark website that might give you an idea on how to re-seat the ribbon in its place.
Printer Cartridge Stalls or Is Blocked
4helpful
2answers
935 Service Printhead error
Error 935
Printhead Error - Mirror motor unable to reach operation speed Check cables, look for chafing or damage to ribbon cable at sharp bends around rear cover. Replace printhead or ribbon cable.
1helpful
I got lexmark x1180 scanner with printer my printer works but scanner is nnot working
Lift the scanner lid up at the back you'll find the 2 brackets that secure it from going to far these if squeezed together alow the lid to open fully. Now with a philips screw driver remove the 4/5 screws (don't drop them inside the printer) Now remove the glass and cover from the top, trace the ribbon cable to its source, mine gradually played its way free after heavy usage all it requires is firmly sliding back into its boss and also check the other end of the ribbon for mucky paper build up. Hope this helps you.
18helpful
5answers
107.08 service printhead error message appears on screen - only installed printer 2 days ago.
Take the back panel off and reseat the ribbon cable in the top middle of the system board..Just got off the phone with tech support and it worked...
1helpful
2answers
I am getting error code 843.01, what is the solution?
Found this information on the web. Hope it helps, because, Printer has been discontinued.
Problem
843 error; 843.01; 843.01 error; Scanner error; Scan error; Cannot scan; Will not scan Solution--Overview
An 843.01 error is generally caused by the Bottom ADF Cable on the scanner being loose or unplugged. Did the error return?
Yes: Continue to Contacting Lexmark
Items is Discontinue
The control panel display is blank on my lexmark x6570 printer
If the LCD on the operator panel constantly displays black bars/boxes or other unusual characters, take the following steps:
1. Disconnect the power supply from the printer.
2. Wait for about one minute, then reconnect the power supply and check the LCD display.
3. If black boxes/bars or unusual characters are still displaying constantly, move the power supply to a different power outlet.
4. If the black boxes/bars or unusual characters are still displaying, the scanner ribbon cable may need to be reseated. Do the following:
1. Lift the scanner flatbed. (Open the printer as if attempting to install cartridges.)
2. Look in the back right corner of the 6150/70 for an access cover.
3. Press firmly on the front right corner of the access cover to reseat the scanner ribbon cable that is located underneath the access panel.
Lexmark E210 laser printer driver not working
I had the same problem two years ago and purchased the adaptor also .The port is correct. My adaptor never would work either. The correct answer,for me, was to purchase a Parallel port PCI card and install it.  I am still using it to this day as both the paper and the ink ribbon  on my pin printer is a lot less expensive for making copies that I don't need to be letter perfect.
Dot matrix printer. very light print on last page of form
Hi and welcome to FixYa,
Based on your description, the printer is working, it is not a form issue, the printer head is good, an adjustment might be needed and it works, there is no reason to replace the Lexmark 2381plus printer even if it is 7 years old (not unless you would want to).
To the faint printing on the last of the 3 pages:
  • the take-up spool/wheel drawing the ribbon is not working (most likely). The ribbon is not moving hence the printer head is not striking fresh ribbon area. Check the ribbon cartridge, it may be stuck or the driving spindle where the ribbon's take-up spool/wheel locks into. It may need a bit of cleaning and/or lubrication;
  • the printer head is slightly adjusted away from the paper. Normally, there is a mechanical lever/adjustment that sets how many paper & duplicates are fed. Adjust for 1 only.
Good luck and thank you for using FixYa.
2answers
I have a 7 year old Lexmark 2381plus dot matrix printer. Recently, the print on the last page of the 3 part form has become very hard to read (very light). I changed the ribbon and have the form setting...
It would seem you posted twice.
Bad ribbon cable
You are not going to be able to purchase a dedicated one thats for sure.
If you arei nto repair you could endevour to make one up from a scrap cable[ide?] and re use the connectors - but I have a gut feeling it will be new Allinone time sometime soon.
Top Lexmark Office Equipment & Supplies Experts
Marvin
Marvin
Mehandi Husain ...
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
