Question about Xerox Phaser 8500/DN Printer
Xerox Phaser 8560 error code 09,037.45:9180. Does anyone know what this error code means?
I got this error code when the printer was warming up. It rebooted itself then brought this error message up. It said to try to turn off and wait then turn back on. I did this 3xs and it still comes up.
3 Related Answers
Anonymous
  • 526 Answers
SOURCE: Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Posted on Apr 15, 2009
darkpain
marios basileiou
  • 316 Answers
SOURCE: xerox phaser 8560 error 04,018.48:26
Hello,this fault code indicates a problem with the process control system.The printhead temperature dropped below the head cleaning needed threshold and that's why stops warming up.The first you need to do is to verify the temperature of the room that the printer is,if its too cold,near from an open window...If was too cold and not in the room temperature then move the printer and your are done.If this doesn't solve your problem run the Monitor Heaters tests with all heaters ON.Are the heaters operating correctly?If yes replace the Electronics Module.If no you have to inspect the harness to the failed heater.Is the harness damaged?If yes you must replace the harness.If no replace the problem component.
Good luck:)
Posted on Feb 04, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Error message on xerox 8560 09,038.46:13269
Go to the Xerox.com website and follow the troubleshooting aid to these types of faults.
Good luck.
Can anyone tell me what code 19,003.48 means for Xerox 8560?
19,003.48: Scale and offset error is too large. The voltages measured have more than a 20% error from their expected values. Something is wrong with the Electronics Module or the Wave Amplifier.
To prevent these discharges, a Grounding Clip (P/N 650442700) was added between the Y-Axis Motor mount and the Pick Clutch. Check that this clip is installed and contacts the metallic portion of the Pick Clutch.
Note
The Grounding Clip is factory installed in later versions of 8500/8550
models and in all 8560 models.
Xerox Phaser 8560DN error code 07,010,43
Sadly, Xerox says that this means "Power off the printer and contact support". Phaser 8560 Support Drivers
However, there is something about "opening the pivot plate", it's Greek to me, but google it and see if you can't reset the brain in the printer and get it back to life without an expensive service call.
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Xerox phaser 8560 error 04,018.48:26
Good luck:)
2answers
Xerox Phaser  8500/DN Printer Logo
Top Xerox Office Equipment & Supplies Experts
Eric Engel
George Mclaughlin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
