Sharp XE-A402 Electronic Cash Register Logo
A
Anonymous Posted on Jun 04, 2014
Sharp register BUTTON NOT WORKING
REGISTER BUTTON FREZ NON OF THEM WORKING, IT STUCK DURING ENTERING PRICE
When turning on our sharp XE-A42S cash register in REG mode it lets us enter in a price, but when we go to push the department key, it beeps and displays misoperation...
Firstly, press subtotal (ST) button. If a price appears, you are in a sale and it is waiting for you to finish (try another method like credit). If it gives an error or beep when you press ST button and the drawer does not open when pressing CA/AT/NS, you probably haven't signed on. Try signing on using a PIN number (see clerk sign on in your manual)
tip
How to REFUND, VOID, ERROR CORRECT on a cash register
Most cash registers are similar in operation when it comes to removing items from a sale (or after one).
ERROR CORRECT, or ERR CORR, or EC will remove the last product you entered during a sale. You simply press it straight after the item button to reverse that item back into stock.
VOID (infinity symbol on Sharp), or VD is used to remove any item from a sale e.g if you have entered four items in a sale, you can remove the first item by pressing VOID, then the item button.
REFUND, or RF, or RFND is your friend. It can be used to reverse any item at any time during, or after a sale. Just press REFUND then the item to reverse it back into stock. Then finish with a payment type e.g CASH if you are refunding cash back to the customer.
-------------------------------------------------------------------------------------------------------------------------- Need a cash register manual?
Sharp, Casio, JCM, Samsung, Sam4s, Olivetti, Royal, Omron, Sanyo, Towa, Geller, Uniwell, Javelin
Available here:
http://the-checkout-tech.com/cashregisters.php
on May 19, 2010 • Computers & Internet
How to program the open misc button
to program an open misc key in the first 10 columns of the keyboard turn key to program and hit 100 subtotal, then press the key to be programmed. enter o and hit time , cash for a non taxable open key or press 400000000 time , cash for open taxable key
Phil
2answers
Can't enter decimal quantities 1.5 @ $5.00.
Depending on the flag setup maybe you might have to start with price then quantity..good luck
XE-A203 SAID 'OVER LIMIT
Each department in the register can be programed with a maximum price. Sharp calls it a HALO, for High Amount Lock-Out, and it prevents those silly mistakes like a cashier once made for me when my burger and shake came out to over $500.00.
If you're entering a reasonable price, but the register complains that it is OVER LIMIT, you need to program a higher HALO for that department. Look for the department programming in the manual.
1helpful
What does inh.unit pr mean
INH. UNIT PR. means "Inhibit unit price". It means there is no price preprogramed for that department or PLU. Each department can be left open-priced, or preset. Open price is how you usually think of using a cash register: you enter a price, then touch the button. Preset price requires programing a price for a department in advance, but saves time in operation. You touch the Coffee button, for instance, and it automatically rings up the price you've set for a cup of coffee.
If you touch a normal, non-preset department without entering the price first, the register will error with the INH. UNIT PR message.
Touch the CLear key, enter the price, then touch the department.
Many of the Sharp registers, and I think the XE-A402 is one, allow a department to be both open and preset. It can also be programed to be inhibited completely.
The Owners Manual can be downloaded from Sharp here.
3helpful
ERROR E32 SHARP ER-A220
hi. E34 means the machine has had a limit programmed into it so that a maximum price can be entered. this stops staff accidentally charging say $1000 instead of $100. Try entering a lower price. The limit can be removed if desired. Mark
Manual for the electronic sharp cash register XE-A101
just search on google manual for sharp cash registers and go to webite of sharp besides when it says that just click cl and help 2 times and start over
Sharp XE-A102 Cash Register
What are you tax tables set up.  This version lets you set up multiple tax tables.  It may be calculating that.
Top Sharp Retail Supplies Experts
k24674
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
