Question about Bunn VPR Coffee Maker
How do I fix my bunn #053213cs from leaking from the bottom
Mark Cheong
    Master:
  • Bunn Master
  • 791 Answers
VPR has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the tank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
Posted on Feb 08, 2018
5 Related Answers
Anonymous
  • 189 Answers
SOURCE: My Bunn coffeemaker NHB is leaking from the bottom
If you will call Customer Service with your Model and Date Code located on the bottom of the brewer, we can assist you with this problem.
Posted on May 19, 2010
Anonymous
  • 189 Answers
SOURCE: my bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Anonymous
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Anonymous
  • 189 Answers
SOURCE: My NHB bunns coffee maker
If you will call Customer Service at 800-352-2866 with the model and code date, we will be able to help you resolve this issue.
Posted on Sep 13, 2010
MotoGenius
Motorola Mobility
  • 3100 Answers
Mobile Phone and accessories
    Verified Fixya Pro
    SOURCE: how do i fix my bunn coffee pot, it's leaking
    Probably need the gasket Bunn can send you. There is a second one that also tgey can't send that goes in the top of tge canister. alltempparts.com/gasket-tank-lid1.html
    Posted on Oct 31, 2012
    2answers
    Bad leaking bunn commerical VPR pour-omatic
    You will need to replace it, parts are not made for repair except under warranty.
    How to fix a leak on a bunn NHBX coffee maker
    The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
    It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
    Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
    Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
    Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
    Re-install the reservoir and reassemble the unit.
    How do i fix my bunn coffee pot, it's leaking at the bottom
    2helpful
    My bunn model b10-b is leaking at the bottom out onto my counter top. so when i add 10 cups of water, I get about 8 cups. It appears to be leaking from the holding tank. The code date is 202103. Is...
    There is a seal kit that is successful about 90-95 percent of the time in fixing the leaking issue. If you will call customer service at 800-352-2866 with your name and address, we will be able to send you a kit to resolve your issue.
    My NHB bunns coffee maker leaks from the bottom when brewing. Is there an easy fix?
    6helpful
    My Bunn coffee maker leaks out of the bottom
    If you will call Bunn Customer Service, there is a seal kit that can be sent out to fix the leaking problem you are experiencing.
    2helpful
    My Bunn coffeemaker NHB is leaking from the bottom onto my counter. Can this be fixed?
    My Bunn Pour-Omatic Coffee Maker leaked all over the counter when I made my coffee. It was mild for a week or two but became very severe. I am pleased to say I followed a suggestion that I found only by...
    Do you have the model and date code located on the bottom of the brewer? If you will call Customer Service at 800-352-2866 we will be able to assist you in resolving this problem.
    2answers
    Bunn coffee maker leaks all over the counter. What
    there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
    if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
    good luck!
    2helpful
    2answers
    Leaking a half cup of water from the bottom while brewing
    Call bunn for replacement gasket free of charge per recall.
    Bunn VPR Coffee Maker Logo
    Top Bunn Coffee Makers & Espresso Machines Experts
    Dennis
    john h
    ADMIN Canada
    ADMIN Canada
    Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
