Dell Inspiron 1200 Notebook Logo
A
Anonymous Posted on Jun 04, 2014
Why is this appearing, memory write/read failure at 4f7e004,read 00917e91 expecting 7e917e91
This appears on screen on startup.Will not let the software load.
medardo vasquez
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 33 Answers
  • Posted on Sep 29, 2014
medardo vasquez
Contributor
Level 1:
New Friend:
Cheetah:
Answers
33
Questions
0
Helped
6512
Points
44
Try to remove one memory stick and see what happens
1 Related Answer
Anonymous
  • 3940 Answers
  • Posted on Apr 06, 2010
SOURCE: i installed new memory chip (in the back) when I
Reseat the memory module, see if issue changes, if not, it appears the RAM is faulty
Memory write/read failure at 4F7E0000, read 7E817E91 expecting 7E917E91
Defective hard drive. URGENT THAT YOU BACK UP ALL DATA IMMEDIATELY so that you do not lose important files, and have the hard drive replaced.
Previous attempts at booting this system have failed at chekpoint {vcls} .for help in resolving this problem , memory write/ read failure at off90000,read f916f912 expecting f916f916 memory address...
Open the router, remove the memory sticks and reseat them. Sounds like the memory channels are having issues if the memory itself isn't the problem.
Why does a message appear saying low beam failure
The test system puts a low voltage out to the lights during initial startup and then measures the drop in ampage. If the result is not what the system expects it turns off the low beam lights to prevent damage and then displays the low beam failure message.
Did you just do an HID upgrade? THis is a very commong result after the upgrade, which is corrected by installing resistors
Video Display problem
The appears to be a video RAM related issue. You can see if running the system on one or the other of the Memory modules makes any difference. If issue goes away on one memory module, then the one out is likely bad. If not, you are looking at a motherboard replacement due to video card failure
2answers
Graphics card failure
the error: (Under this test, results show Error code 5300: 0119, which different comments for different parameters) Msg: Detected a failure while writing and reading video memory. (e.g.) Video mode: Dh (320 x 200 16) Address A002Ch, expected to read Oh, but read 1Dh instead *
indicates the video card has failed and need to be replaced.
5helpful
4answers
Dell inpiron 1535 laptop - memory write\read failure
memory write/read failure at 14020058,read ED22ED02 expecting ED02ED02
decreasing available memory
I have an Acer Aspire 5100. Right now I have error code 0X490 &0X2. How do I fix this problem after my laptop crashed. I can not find my startup disc.
this is a graphic card driver issue
memory hex errors, memory double word logic failure at [ hex value], read [hex value],expecting [hex value]..
hexadecimal, may be a bad memory address,
memory line parity error at [hex value]
without more information i cannot help you
rod
Multiple failure notices on screen
your system memorey have a leackage problem, replace a new memory as soon as
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
