Acer Aspire 4520-5582 Notebook Logo
A
Anonymous Posted on Jun 04, 2014
ACER PREDICTOR C5900 - Acer Aspire 4520-5582 Notebook
sharky633
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Acer Expert 510 Answers
  • Posted on Jul 26, 2014
sharky633
Acer Expert
Level 2:
Prodigy:
Answers
510
Questions
0
Helped
62559
Points
697
I think you mean a Predator? and again you are so proud of it that you want to tell the world you have one...No ! Whats the problem ????? Lol !!
I cant get into my account my e mail wont let me in. name Rita Timberlake Cahill
Ok. Are you Bob posing as Rita or Rita posing as Bob. Is this your account, your daughter's, wife's, girlfriends etc or are you a predictor?
Sony tv color predictor 2004 when turn on standby mode
Check that the TV is receiving a "source" (VCR? cable-box? disconnected coaxial cable?
How to calculate regression analysis
It depends on what your doing, lets just say you want to compare two curves to the same data. First off save the fitted valurs from each model in the worksheet, which you can do by checking the "fits" in the storage dialog. Save the fits for all models you want to compare which I call fit1 and fits 2.
Then you create a scaterplot and display the
Following pairs, original response and predictor data. Fits 1 predictor data fits 2 predictor be sure to check overlaid on the same graph on the multiple graphs dialog. After you create a graph you need to teek it by adding connect lines. Click on the data point on the scatterplotin the menu choose, edit> Add> data display "connect line". This will connect lines to all your datasets, unfortunately you don't want that don't sweat it easy fix to make that go bye bye slowly double click on the connect lines on the original data, which selects the specific connect line, if you do it to fast it will bring up the dialog to edit all connect lines so slowly double click you know like a finger spasm lol. Anyways right click and choose edit connect lines choose custom scroll up and choose none and thats it tour done. Hope this helped
Its a predictor 6.5 HP / 215cc motor starts with choke but don't stay running
Carburetor most likely needs a good cleaning or replacement. Sound like the main fuel passages are clogged.
Jul 22, 2014 • Garden
Error 980 on OKI C5900 fatal error
First, there is no model C5900. There is a model C5800. On the assumption that you are having this issue with a C5800 then the problem is media wrapped around the fuser. After cooling you can try to unravel or unwind the wrapped media but you may need to replace the fuser.
How tall is the women femur is
Femur length has become one of the leading predictors of fetus growth. According to the National Institutes of Health, ...What is the average length of a woman's femur? The average adult human femur is 48 centimeters in length and 2.34 cm in diameter.
Femur length has become one of the leading predictors of fetus growth. According to the National Institutes of Health, there is a direct correlation between length and height. The agreed formula is 6.18 + 0.59 x femur length in millimeters.
C5900 blu ray won't connect to Internet@tv
You may have to follow the owner manual and do a full setup of all features the unit has.
2helpful
Hi, I have a Samsung Blu-Ray BD-C5900 and I it does not play all regions DVD's, I would like to play all regions on m Blu-Ray, is there a code that can set this up?
Turn your BD on without cd in it, wait until appear no disk on screen.
Use this combination : Repeat-5-6-7-3-2-9
You should seen "9" on right of screen.
Good luck.
7helpful
I have a problem with my Samsung BD C5900 blu ray player. When I try to activate the internet @ TV function it will not open the internet page. It instead tries to load a new firmware. A icon appears...
I have just installed the BD C5900 and have exactly the same problem. Spoke to Samsung and they say your have to switch the blu-ray off and on the front of the blu-ray player itself press and hold the stop button for approx 30 seconds (small square symbol). This is a master reset. You then follow the set-up procedure as you did when you first installed the blu-ray. I did this and mine works fine now and has the latest software version BSP-C5900WWB-1009.1 installed okay now, and everything including internet accessable once again..
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
