To open a locked memory card, select Options > Unlock memory card. Enter the password. If you cannot recall the password to unlock a locked memory card, you may reformat the card, in which case the card is unlocked and password removed. Formatting a memory card destroys all data stored on the card.
Encryption Select Menu > Tools > Encryption. Encrypt your device or memory card to prevent outsiders from accessing your important information.
Encrypt device memory or memory card
To encrypt the device memory,
select phone memory. To encrypt the memory card, select memory card from the following:
Encrypt without saving key
• memory card without saving the encryption key. If you select this option, you cannot use the memory card in other devices, and if you restore factory settings, you cannot decrypt the memory card. Encrypt and save key
• and save the key manually in the default folder. For security, store the key to a safe place outside the device. For example, you can send the key to your computer. Enter a pass phrase for the key and a name for the key file. The pass phrase should be long and complex.
Encrypt with restored key - Encrypt the memory • card with a key you have received. Select the key file, and enter the pass phrase
Do your other devices support 64bit wep, and are you selecting that as your encryption type on each device. For example I know on my cellphone I have to specify the type of encryption that is used. You might also log into the router, just to double check the encryption type and the pass phrase (even if you are spelling it right).
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
To record you hold down"store" and hit "1" that opens the storage unit. Type what you want to keep. when finished press "store" again. that closes that storage unit. When you want to play that , hold "play" and tap "1" that storage unit will play out. You can repeat this in storage areas "1" to "99" until the memory is full. To delete the storage unit, hold "delete" and hit a paticular storage area, such as "1" all will be deleted.
I don't know if you ever received a solution to your problem, but you might try taking the batteries out and putting them back in again. If this doesn't resolve the problem, I would take the unit back to the store where you purchased it. If this helps, please give me an appropriate rating and thanks for using FixYa.
you can store phrases by -
1 - turn on the AUTO RETURN button above the keyboard
2 - hold down the button on either side of the spacebar, type a titile (any character from a - z)(SPECIAL ENTRY light will turn on)
3 - hit the +/= key (if you hear a beep, it means this title is already used. Press STOP and start over with another title.)
4 - type the phrase
5 - hold down the special key on either side of the spacebar and hit any key (a - z) to store the phrase (SPECIAL ENTRY light will turn off.
to re-call a phrase
1 - hold down the key by the s/b and type the title (SPECIAL ENTRY light turns on)
2 - press the SPACEBAR one time
The WW 2000 has a memory. Press and hold the store key and 1 thru 99 as an address, when typing is complete perss store again your info is now stored in that adress. To play it back press play and the adress.
