SOURCE: The fuser error light is on and my Xerox XC 1040
The drum light can be reset via the control panel. Especially if your copies were good before the light came on. The drum unit is the cartridge that is located right next to the toner cartridge. Reset the light using the following reset procedure:
To reset the drum light on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
Testimonial: "YOU ARE MY HERO !!! UP AND RUNNING. THANKS SO MUCH !!"
