Frigidaire FMV145K Microwave Oven Logo
A
Anonymous Posted on Jun 04, 2014
HOW TO REPLACE A MAGNATRON IN A MICROWAVE - Frigidaire FMV145K Microwave Oven
1helpful
Microwabe is not heating anything
Sounds like the magnatron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnatron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnatron, they replace the whole oven.
There is a possiblity that the circuit that provides power to the magnatron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it appart. It is a fairly lengthy process however.
1helpful
Mm5165bas, light comes on, fan works,carousel doesn't work , does not heat.
Hi, it sounds like the magnatron has failed. This is the component that produces the microwaves that heats the food.
2answers
Microwave runs and sound normal but nothing gets hot.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Maytag microwave is not heating and the time runs back fast.
There is a possiblity that the circuit that provides power to the magnatron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it appart. It is a fairly lengthy process however.............
2helpful
Strange noise, no heat
GE spacemaker xl1800
more than likely the fuse has blown onthe magnatron it is the button looking thing on the magnatron with two wires. there are 2 of these one is on the magnatron the other is above the heat box test these for open. if open replace. if good then replace the magnatron.
Not heating
Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
2answers
Microwave makes loud noise and does not heat. Smell of light burning
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Micowave power
Hope ya fix it!
Top Frigidaire Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Jerry Naidoo
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
