How to connect a RCA Subwoofer RT2760 to a MCS 3233 Stereo Receiver
mike shaw
    New Friend:
I just plugged my sermon Vega powered subwoofer into tape one out record I have a mini disc deck into the auxiliary and it all works perfect I don't change a knob or turn nothing or anything
Posted on Feb 13, 2018
1 Related Answer
yeroc
Custom Exchange
  • 397 Answers
SOURCE: no sound coming from subwoofer
sometimes these subwoofers are for builtin amplified subwoofers..so if this is the case it will not work
Posted on Jan 20, 2008
Why does my MCS sub 10 not turn on?
Is that the right part number, MCS 10, and not MCS100?
The MCS systems use a basic sub which is matched to the satellites. There's very few controls other than level on the MCS100. So as long as the power light is illuminated the there's very little other than the volume control that could be set wrong on the sub. So what it comes down to is either
  1. a blown fuse (no power at all at the sub);
  2. a broken input (#1 cable, #2 sub input socket, #3 blown sub plate amp);
  3. incorrect connection at the receiver end or the wrong settings
As a quick test, unplug the sub cab from the amplifier/receiver end. Switch on the sub and turn the volume down all the way. Briefly put your finger across to short the RCA/phono tip and ring. The sub should make a buzzing sound. You now know that the sub is working and the cable appears to be okay
Switch off the sub and reconnect the phono/RCA to the sub out socket on the receiver. You now know it is connected correctly.
Go in to the receiver's menu and check the speaker settings. Is subwoofer present? Yes/No
Are the satellites all set to Small? (they should be with this system)
Are you playing a 5.1 source in DD or DTS to ensure that the sub gets a signal? Play a BD or DVD.
On the speaker balances, is the sub channel set to 0dB?
As long as all the above is set as listed, then the only things stopping the sub working would then be insufficient volume at the sub's Vol control (so increase it), or an intermittent cable connection (wiggle the cable), or a broken subwoofer out signal at the receiver.
Aug 06, 2014 | Boston Acoustics Audio Players & Recorders
Someone cut the power cord on my subwoofer RCA model rt2760 can i replace it with a standard plug?
if its a standard 120/ 240 volt cord with three cores live /nuetral/ earth yes
Aug 02, 2011 | RCA RT2760 System
Power light blinks and will not power up
My RT2760 started doing that about 2 months ago, and I found the subwoofer connector on the back of the receiver is loose. If you wiggle it around, it will come back on.
Dec 29, 2009 | RCA RT2760 System
There are 2 sets of wires on the rca rt2760 home theatre system subwoofer, i know thay the purple ones are the speaker inputs......but the red and black is dc input for the amp thats inside the...
one is for the speaker connection the other is a control wire for the sub that should have a white plug on it to plug in the back of receiver
Oct 13, 2009 | RCA RT2760 System
No Audio with home theater system
have you tried infra red link?
May 07, 2009 | RCA RT2760 System
How to connect unpowered subwoofer to receiver with RCA sub out?
In order for this to work, you will need an external amplifier. Your receiver is set up to use a "powered" sub. With only speaker connections on the sub, it is a "passive" sub requiring a separate amp.
Dan
Dec 16, 2008 | Yamaha YST-MSW10 Computer Speakers
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Subwoofer connection
    if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
    Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
    127 people viewed this question
    Muntejaya Ginting
    Muntejaya Ginting
     Grubhead
    Grubhead
