Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
I took the hoses off of my bissell pro heat 2x 9500 they are not right
5 Related Answers
Anonymous
SOURCE: bissell Pro heat 9500 2X
I had this same problem, even went out and bought a second machine, same problem. Here was my problem....I was checking the brushes while the handle thingie was in the upright position. You have to be sure and RELEASE THE HANDLE. Now i have 2 perfectly good Bissells.
Posted on Jan 26, 2009
Anonymous
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
Anonymous
  • 6 Answers
SOURCE: need pics of bissel hose assembly
Just what the doctor ordered:
http://c.managemyhome.com/mmh/answers/Answers.action#l4q145526
This is not my website, you should thank the guy that made this. It took me a few days of searching to find it.
Posted on Nov 18, 2009
blademan1973
  • 26 Answers
SOURCE: Bissell Pro heat 2x the shampoo tank empties out
the o-ring is likely dislodged on the screw on cap
personally I would recommend just filling the soap container with water and a little bit of white vinegar instead of the detergent. You won't leave soap residue in your carpet that way.
Posted on Dec 23, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum: I have a Bissell proheat 2x deepcleaner 9200 model...
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fkj
Posted on Sep 30, 2010
Bissell pro heat 2X pet will not spray water.
Bissell 2X machines all seem to do this after 4 or 5 uses. It's a bad solenoid. Most vac shops won't touch the 2X with a 10 foot pole. Get a Hoover 5914 and stay problem free.
Oct 18, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brush Bar not turning on a bissell pro heat 2x
Here is the Instruction or User Manual for the 9500 series machines
will give instructions how to check and change drive delts
Dec 12, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
USER MANUAL FOR BEX BISSELL PRO HEAT PLUS 2X + MODEL 9500-E
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
BISSELL 9500 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 15, 2012 | Bissell Vacuums
The water in my bissel pro 2X heat will not spray water
front tank is warped and not seating properly or solenoid bad. solenoid most probable.
May 05, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dec 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need pics of bissel hose assembly
Nov 13, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Want to use Bissell Pro Heat 2X Clean Shot. Have
You can download a user manual from the Bissell website
Sep 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I need instructions for bissell pro heat 2x cleaner
you can dawnload it from the manufacture,s website.you should go to there and dawnload it.
Sep 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
Top Bissell Vacuums Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
