Question about Sharp AR-5316 Advanced Digital Imager Copier
CODE F 204 FOR ARM 150
SIMMULATION
Gift Ntwana
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
CRUM data read trouble
Replace the toner cartridge.
Replace MCU PWB.
Replace MCU PWB EEPROM
Check and fix connection between
CRUM (toner cartridge) and MCU
PWB.
Posted on Apr 21, 2016
Q6 edge code #204 brake diseconected
Glizid 80mg
Buy Glizid 80mg Online, Dosage, Price, Side effects
May 27, 2018 | Health & Beauty
Postal code for 138 16 St. Salmon Arm, BC
This is the closest I could find:
150 16 ST NE
SALMON ARM BC V1E 1N5
Oct 10, 2014 | Computers & Internet
Error code E000530-0000 in ir 3300 imegrunner
mohon sulusinya ir3300 saya error code E000530-0000
May 10, 2011 | Computers & Internet
How to security code nokia 3315 V05.47
hello sir, enter this master code if your phone ask for a security code...3220325056 in case your phone does not recognized your sim card ,your phone is in network locked status so you need this unlocked code...i calculate it for you ,try the first one ,if not work enter the next one....type this without the sim card #pw 324 146 544 203 755 1# #pw 424 847 743 220 057 2# #pw 336 566 150 437 573 3# #pw 107 894 327 500 204 4# #pw 232 225 257 034 133 5# #pw 038 113 450 633 027 6# #pw 918 422 734 646 632 7# note: to enter ,press 2 times the * to enter p ,press 3 times the * to enter w ,press 4 times the * goodluck and thanks for trusting fixya...
Dec 05, 2010 | Nokia 3315 Cellular Phone
Need to replace ball joints
http://groups.yahoo.com/group/villagerquest/ Ball Joint Removal
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the suspension lower arm ball joint cotter pin.
  1. Remove the suspension lower arm ball joint nut and separate it from the wheel knuckle.
May have to leave nut partially on and hit the nut hard with a hammer to knock the tapered stud down and out. May have to hit side of knuckle to help get it to drop. or rent a pickle fork to drive between the bal joint and knuckle.
  1. Remove the suspension lower arm ball joint to suspension lower arm nuts and remove the ball joint.
Nov 15, 2010 | 2001 Nissan Quest
How to replace a Jaguar X Type fron wheel bearing
Jaguar 2000-06
Wheel Bearings
Removal & Installation
  1. Remove the brake disc.
  2. Remove and discard the retaining clip. Detach the ABS sensor.
  3. Remove and discard the O-ring seal.
  4. Remove the wheel hub and bearing retaining bolts.
  5. Remove the wheel hub and bearing.
  6. Prior to applying sealer, clean the ABS sensor sealing surface and the ABS sensor aperture sealing surface.
  7. Install a new O-ring seal.
  8. Apply a 2.5mm bead of Loctite Ultra Blue 587 Silicone (RTV) sealer to the ABS sensor sealing surface.
  9. Install a new ABS sensor retaining clip.
  10. Install the hub/bearing assembly. Tighten to 90 Nm.
  1. Remove wheel knuckle.
NOTE When removing the wheel hub from the wheel knuckle the bearing will be destroyed and the bearing inner ring will remain on the wheel hub.
Fig. Using special tools, remove the wheel hub-X-Type
  1. Using special tools, remove the wheel hub.
  2. Using a suitable tool, remove the bearing inner ring.
  3. Using special tools, remove the wheel bearing.
    Fig. Using a suitable tool, remove the bearing inner ring-X-Type
    Fig. Using special tools, remove the wheel bearing-X-Type
To install:
Fig. Insert special tool 204-312 in to 204-309-X-Type
  1. Insert special tool 204-312 in to 204-309.
  2. Support the wheel knuckle on special tools.
NOTE Make sure wheel bearing is correctly orientated with the colored side facing inboard.
  1. Align the bearing over special tool.
  2. Using special tools, press bearing into wheel knuckle.
  3. Change special tool 204-312 to 204-313.
  4. Align the bearing and wheel knuckle over special tool.
  5. Slide wheel hub over the guide and align to the bearing.
  6. Using special tools install the wheel hub.
  7. Install the wheel knuckle.
    Fig. Using special tools, press bearing into wheel knuckle-X-Type
    Fig. Change special tool 204-312 to 204-313-X-Type
    Fig. Align the bearing and wheel knuckle over special tool-X-Type
    Fig. Slide wheel hub over the guide and align to the bearing-X-Type
  1. Raise front of vehicle and support on stands.
  2. Remove appropriate road wheel.
  3. Using wire or string, secure brake caliper to road spring to take weight off brake hose.
  4. Raise vehicle sufficient to provide access for special tool 204-111.
  5. Install special tool 204-111 in road spring.
  6. Slacken tool adjuster to suit spring length.
  7. Install adaptor and thrust collar.
  8. Position stem of tool in center of spring passing dowel through slot in suspension turret.
    Fig. Install special tool 204-111 in road spring-XJ Range and XK Range
    Fig. Position stem of tool in center of spring passing dowel through slot in suspension turret-XJ Range and XK Range
NOTE When turning tool adjuster, ensure that tool stem does not rotate and disturb position of dowel in suspension turret.
  1. Engage dowel of special tool 204-111 in suspension turret and rotate to position across slot.
  2. Lower vehicle onto stands.
  3. Rotate tool adjuster to tension spring.
  4. Remove wheel speed sensor securing screw and withdraw sensor from vertical link.
  5. Remove nut securing tie rod outer ball joint to steering arm.
  6. Release ball joint from vertical link.
  7. Install special tool 211-098 on tie rod outer ball joint.
  8. Tighten tool bolt to release taper pin from vertical link.
  9. Remove special tool from ball joint and position tie rod for access.
  10. Remove nut securing upper control arm ball joint to vertical link.
    Fig. Install special tool 211-098 on tie rod outer ball joint-XJ Range and XK Range
continue...
Aug 03, 2010 | 2002 Jaguar X-Type
Engine diagnostic code 204
204 injector 4 circuit malfunction 304 cylinder 4 misfire detected if there is power to the injector most likely the injector is bad.
Jul 31, 2010 | 2000 Dodge Caravan
Acer Aspire 8920G error code 204. I received this
Problem solved, sent to acer, they installed a new cd-rom.
Dec 11, 2009 | Acer Aspire 8920-6048 Notebook
Where is the batter on a Meridian 204 tuner
A 3.6 volt 150 mAmp/ hour NICAD battery is soldered to the bottom PCB Com board
Apr 14, 2009 | Audio Players & Recorders
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
