Hi, Sim 1 is working perfectly fine, but Sim 2 is sometimes working and sometimes not working, I was told it was a service problem with Sim 2, but I had Sim 2 with another phone before I got this one, and now Sim 2 sometimes does not receive ,I can call others but is not receiving the call and within the day I would receive a sms message saying I missed the call, when it was never ringing..Is this really a service problem or a Sim problem?
SOURCE: samsung prostar 816 plus system ringing problem
sounds like your having a couple of problems at the same time. the lines only ringing at station 1 is the default setting of the system my guess is that the time and date are also way off if thats the case.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
press #when finished.
next, the problem with the cordless not working has to do with the port programming, in default it assigns all ports as multiline sets.
To assign a SLT(single line telephone) port to the system while still in program mode dial #38 the screen should say slt dial type and then 16 0's.
0 = keyset 1=slt set
enter in all 16 digits followed by the # i.e.if your cordless is on port 7 it would look like 0000001000000000 #
lastly the phone that can no lnger recieve calls sounds like the do not disturb or DND has been pressed to stop the alarm from ringing. press the mute/dnd button (light should be off). to cancel an alarm press the ALM/SD button twice and then the hold button.
hope that helps out.
SOURCE: Message memory gets full though the capacity is 500.
yes... i am also getting same problem.
total SMS memory is 500 ie 200 for inbox , 200 for sentbox, 50 outbox and 50 for drafts. your my folder SMS's are still considering in inbox. that should not be more than 200.
thanks
kuldeep chanchal
SOURCE: sms memory full del some sms
Your Inbox Only support 200 sms... And when I say Inbox it includes your My folder as well... So you see 197+ 26 beyond your range... Delete Data from my Folder.... Problem solved.
SOURCE: broken message, Samsung mobile
sure they have not updated the software, they might only have factory reset it.
