Question about Canon imageRUNNER 8500 Copier
Solusi error canon ir 6000 E000061-0001 - Canon imageRUNNER 8500 Copier
5 Related Answers
Cogz
Chris Coughlin
  • 1326 Answers
SOURCE: Alignment of Tocuh Screen Panle of Canon Copier IR-6000/6001
I believe under the aditional funcation screen, you can calibrate the touch screen. Is the screen working at all? Does it look like there is Water on it and you can not wipe it OFF. If so, the display screen is cracked and needs to be replaced.
Posted on Apr 02, 2009
Anonymous
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
Anonymous
  • 1219 Answers
SOURCE: ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Posted on Apr 26, 2010
Anonymous
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
Anonymous
SOURCE: getting a problem with a canon ir 6000 error code
ji guys I need ur help, I've error code on cannon ir6000 "000732-0001", please help me send to my mail [email protected] ty
Posted on Sep 16, 2010
1helpful
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
IR 6000 - Error conde E10,E12 and E14 after 5 to 10 min of starting
Error E10/E12/E14: Main cause: The main motor (M1)(M2)(M19) is faulty. The DC controller PCB is faulty.Mode of detection:0000 The clock pulse do not arrive for 2 secs or more after the main motor drive signal
For more help you can check the canon iR6000 service manual from below link:
http://goo.gl/yhuA4J
thanks
3helpful
2answers
Error e350 canon ir 6000
pls help canon ir6000 error E350-3000 solved the problems
Canon ir 6000 service support tool
I need sst firmware of canon ir6000 can anyone help me out my email id is [email protected]
2helpful
3answers
My canon ir 6000 is showing an error codes E000001-0000 How it will solve?
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
15helpful
3answers
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
11helpful
3answers
Canon IR6000 shows error code E000061-0001
A E00061-0001 deals with the drum charge is missing. I would look to see if the primary charge unit is installed correctly, if so I would pull the unit out and make sure none of the corona wires are broken.. could be one of the post wires or the grid is broken. You may also, have a end block that is arching out. If you are not a service tech, you will need to call one to repair the code. It can't be cleared till it is fixed... Good Luck
Canon imageRUNNER 8500 Copier Logo
old marine
old marine
Ekse
