Question about Canon imageRUNNER 8500 Copier
E0061 canon 1100
Error 0061 error 070
Carl Wiehe
    New Friend:
  • 64 Answers
Primary charge failure .broken wire or not seated or arching to the grid.
Posted on Jan 06, 2015
Canon ir6000 error code E0061
Dear
Select COPIER>DISPLAY>DPOT in service mode.
If the difference between VDM and VDT is less than 6V,then check laser scanning unit shutter mechanism. if more than 6V,then go 'Display COPIER>FUNCTION>MISC-P>PRE-EXP' in service mode.Check if the preconditioning LED lights. If the LED does not light, replace the LED.
if problem not shut out check all harness related to DC CON pcb to LSU. Cross check the LSU and DCCON pcb.
Check the ram cleaned.
Thanks.
Canon ir6000 error code is morning E0061
Dear
The mode selection has problem, pl. check the laser unit shutter, LSU and DC controller PCB.
The above are the measure if the error code has no sub-error.
Thanks.
Error e000061 0001
Canon and the other major brands use the same codes for multiple machines, I don't see that code for it.
check out the list
Visualhawk solution Canon error codes
Error code h2
Pre-exposure lamp
Does the pre-exposure lamp turn on during copying operation?
Check the wiring from the DC driver PCB to the pre-exposure lamp; if normal, replace the pre-exposure lamp.
12helpful
2answers
Code erro e000061-001 e e000061-002 ir6570
canon copiers model ir6020i show code E000061-0001 what happen wiht my copier and how to solve this problem?
3answers
Mi copiadora IR 5020 se para y arroja cod E 0000020 y manda a apagar y encender el equipo que es este error
check the toner hopper maybe the toner is empty or the hopper motor is failed to fuction
4helpful
Error 61 01
A E0061 is a problem with the drums main charge unit. I would check to see if you have a broken corona wire in the main charge unit & look to see if they are burnt out. I would first replace the post corona wires first and make sure the unit is installed correctly... Good Luck
2helpful
Error E061 & 0070
rewire your corona and change your grid if the error still presis change your drum
13helpful
2answers
Error E061 & 0070
grid bias at upeer limit
Canon imageRUNNER 8500 Copier Logo
old marine
old marine
Ekse
