Vtech 5867 Cordless Phone Logo
A
Anonymous Posted on Jun 03, 2014
How do I get my vtech DECT 6.0 handset to ring when off the base
Cant hear the phone ring when I take the phone outside off the base
4 Related Answers
Anonymous
  • Posted on Oct 19, 2008
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Anonymous
  • 47 Answers
  • Posted on Jan 06, 2009
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
Anonymous
  • 30 Answers
  • Posted on Sep 11, 2011
SOURCE: the phone rings.but i can't
you can contact the mobile service provider........
Anonymous
  • Posted on Aug 18, 2013
SOURCE: How do I DE-register a Vtech DECT 6.0 wireless
menu
*7890#
Test handset
select
arrow down to "Next Page..."
select
Regstr Clear
select
select again (Reg Clear ?)
You get "OK"
Off
Off (you're backing out of the whole menu)
Off
Off (You now get "Out of range or no pwr at base"
Pull the battery
Replace the battery
(you now have an unregistered handset)
Thank you, this worked for me and I can now register my old handsets from my lightning struck base to my new base, (of a different model, but it still works.)
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
My vtech digital 6.0 cordless phone says not registered but when someone calles the base of the phone still rings and people are able to leave messages but the actual phone isnt ringing, how can i fix it?
The base and the handset are not communicating. To have them do so, you need to "register" the handset with the base. Since you neglected to specify the model of your VTech DECT 6.0 phone I can't tell you how to do that. I can suggest you enter the model number into the search box here to download a copy of the manual. The manual will give you instructions on how to register the handset.
I have a cs6328-3 model vtech digital ans system. It is only 1month since purchase. the three handsets are the original handsets and i have no additional handsets that were added. Error: out of range / no...
Periodically, while using my Vtech Model CS6328-3 phone, it becomes virtually impossible to hear the other party - interestingly, it affects other non-cordless phones in the home at the same time. Just like that, the volume may come back. The person on the other end sometimes has the same proble hearing me - but not always. Have switched back to a previous Panasonic phone system in the interim, no problems. Seems to be the Vtech system. Any thoughts?
1helpful
The handset lights up and the incoming number is shown but you dont hear it ringing
Many times there is a volume switch on the actual handset itself. Most commonly on the left side of vtech devices. there are three different volume levels. By pressing up on the button you should be able to turn the volume up until it has an audible tone confirming volume change. Handset should ring with incoming call when audible tone is heard by pressing up on volume button.
1helpful
2answers
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
3helpful
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
3helpful
6helpful
3answers
Tesco ARC200 Cordless DECT Phone
[ARC20x User Guide p20: 11 Handset Registration]
To register a new handset:
  1. Press and hold the HANDSET LOCATOR on the base unit until you hear Registration tone (repeated 'beeps')
  2. On the handset, press the PROG then the UP or DOWN button to display "REGISTER"
  3. Press the PHONE/OK
    -> The display shows "BS 1234". If any of these numbers is steady (not flashing), then the handset is already registered to that base unit.
  4. Press 1 to select base unit number 1
    -> The display shows "BASE PIN _ _ _ _"
  5. Key in the system PIN (default 0000) and press the PHONE/OK
    -> The display shows "WAIT _ _ _ _" for a few moments, while the handset searches for a base. Then it shows a list of handset numbers which are still free on the base unit.
    (For example, "1 34 6" indicates that numbers 1, 3, 4 and 6 are free; 2 and 5 are already assigned to other handsets.)
  6. Key in a free handset number
    -> After a moment, the display should show the handset's name and number.
If registration fails...
  • Try again, making sure you begin step 2 as soon ans Registration tone starts.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
